George Ab
- Pacific NW
Would someone who recognizes what I am requesting provide? Require as am retrofitting an OEM Lighting Package, Bi-xenon with Adaptive Front-lighting System (AFS) and need to see how applicable channels of a Lighting Package MK7 GTI are configured, such as Leuchte 10 and 11 Shutter are configured.
DIY OEM Lighting Package retrofit will follow in a couple weeks. The project is involved, but a doable do.
You VAGCOM folks likely have the file here: [FONT="]C:\Ross-Tech\VCDS\Logs. [/FONT]Process to save channel map is here: http://www.ross-tech.com/vcds/tour/controller-channels-map.php Open VCDS, select applications, select controller channel map, controller address is 9 (electronics), security access 31347, check mark adaptation and measuring values, and save as CSV file.
PM me so I can provide my email address or point me to where it located.
Thanks in advance!
Thanks in advance!
