Burger Tuning JB4 Golf 1.8TSI MQB specific information thread
ghost101101
NC
2016 Golf SE 1.8 TSI
I'd do more runs with the 2nd and 3rd and see how they log. #4 is not benefitting your power and on the edge.
Here's one of mine from last summer. This was stock jb4 fol of 45.
11-13-14.5-15.5-16.5-16.5-16.5-16.5-15.5-14.5-13.5-12.5
https://datazap.me/u/goodvibes/11-1...155-145-135-125?log=0&data=1-4-11-25-26-27-28
I'm currently on your map #3 that I suspect I recommended with FOL 50 (not needed) but haven't logged it this year. At this point it's about gas quality and minor variations in vehicles. I might leave it and try bumping 4500 by 0.5 psi to 16.5 to try and even out the boost curve
Alrighty, here are some more runs.
11-13-14-14.5-15-15-15-15-14-13-12-11
https://datazap.me/u/mattcarr/11-13-14-145-15-15-15-15-14-13-12-11-0?log=0&data=1-4-11-15-25-26-27
11-13-14-15-16-16-16-16-15-14-13-12
https://datazap.me/u/mattcarr/11-13-14-15-16-16-16-16-15-14-13-12-0?log=0&data=1-4-11-15-25-26-27
11-13-14-15-16-16-16.5-16-15-14-13-12
https://datazap.me/u/mattcarr/11-13-14-15-16-16-165-16-15-14-13-12?log=0&data=1-4-11-15-25-26-27
goodvibes
IL
Honestly, I'd stick with the 1st one and maybe take another .5 off from 6k up since you aren't using the power there anyway. I think I get a little better gas here. You're holding more boost and have enough overall advance in the 16 psi curves but they probably don't feel much stronger because the timing is taking a hit in the midrange where that extra boost is. Curves have the right look for a 1.8 boost curve with that octane.
ghost101101
NC
11-13-14-14.5-15-15-15-15-14-12.5-11.5-10.5
https://datazap.me/u/mattcarr/11-13-14-145-15-15-15-15-14-125-115-105?log=0&data=1-4-11-15-25-26-27
To sum it all up, I’m just going to run Map 2…. JK, thanks for all the helps. I will log each year or when gas changes to make sure things look alright.
Winter
1500 12
2000 12
2500 12.5
3000 13.5
3500 13.5
4000 13.5
4500 13.5
5000 12.5
5500 12.5
6000 10.5
6500 9
7000 8
Summer
1500 12
2000 13
2500 14
3000 14.5
3500 15
4000 15
4500 15
5000 15
5500 14
6000 12.5
6500 11.5
7000 10.5
ZuMBLe
NY
Alltrack 6MT
Winter
1500 12
2000 12
2500 12.5
3000 13.5
3500 13.5
4000 13.5
4500 13.5
5000 12.5
5500 12.5
6000 10.5
6500 9
7000 8
Summer
1500 12
2000 13
2500 14
3000 14.5
3500 15
4000 15
4500 15
5000 15
5500 14
6000 12.5
6500 11.5
7000 10.5
Don't get hung up on the numbers. The last log looks good. What's important is you learned how to tune your car.
ghost101101
NC
Yeah, I enjoyed it. DIY was why I went with the JB4. It was like overclocking a PC, satisfying. Actually, it was really like the opposite of under volting a GPU to lower temp. Just replace MHz with RPM and voltage with gas.
Kenjeet
Utah
'19 Alltrack SE 6MT
Does anyone here have any experience running an aftermarket DP w/ the JB4? Everything is stock currently. I have an APR DP and am wondering if I need to tweak anything with my JB4 unit if I install it.
ZuMBLe
NY
Alltrack 6MT
You just need to install a spacer and tweak it so you don't get a CEL. The JB4 can't do anything about it (anymore).
goodvibes
IL
I wonder of you could load another country's SW to maintain the CEL cancelling. Spacer still a better way to go.
ZuMBLe
NY
Alltrack 6MT
You probably could. With the JB4 blanking the CEL, you lose cruise control though. You're better off just getting the spacer setup right.
BigCanoe
Moncure, NC
2017 GTI SE DSG
Can I purchase a used Group 2 or 3 for the 2.0T and use it on my Alltrack? There are more of these for sale than the 1.8T version.
ZuMBLe
NY
Alltrack 6MT
They are all the same. Get the 2.0t version. I strongly advise you to get the bluetooth for it.
goodvibes
IL
I'm sure it's a lot easier and informative while rolling but I'm perfectly happy with the USB functionality.
