anotero
- Hither and thither
- Mk7 GTI
I am in search of advice.
I experience a vibration in what feels like the chassis of my GTI upon braking (high-medium to strong brake pedal depression). The vibration is not overly strong and is accompanied by a strong deep buzz; no vibration in steering wheel or brake pedal (at least none that I can speak of). Vibration occurs at around 50-55+ mph when braking from 65mph to 80mph (have not tested braking at higher speeds). The vibration does not continue until stopping, instead goes away after the speed drops by about 10mph after onset.
Here's what I've done: had my front brakes changed (calipers, carriers, rotors, pads, brake fluid), had my rear brakes changed (rotors and pads). Same result as with previous brakes all around. I did not brake hard with new brakes, however my front rotors have multiple concentric rings that are similar to heat rings. At the same time I highly doubt that is the cause of the vibration -- my rear rotors that I took off looked like ass, but the problem persists with new rear rotors, which are in a pristine perfect condition. Front wheel bearings seem to be fine (I tested by moving the wheels left-right and up-down; no sounds, no squeaks, no rattles).
What are possible causes of this vibration and what are ways to diagnose the problem? Thanks in advance.
