DW58
- Moray, NE Scotland
Must do this as I've got heaps of those damned LED bulbs after screwing up my ebaY order.
Same led unit for the boot lamp can be used in vanity mirror lighting. Just done it massive improvement.
these are 39mm instead of the 42mm in the boot. in saying that you can actually squeeze the boot lights in there if you are careful.
Have you any photos to share how to fit or how the vanity lighting looks?
The LED is way to bright for the vanity Mirror. Tryid it, did'nt like it and changed it back
That was in the back of my mind.... 16 LEDs sounded a bit much. But I did order them about 3 hours ago..... Shoulda waited till I read this then le0n?
I've fitted the 42mm (16 element) led in the boot, and makes a great difference, but after fitting them in the vanity lights, like le0n, I found them far too bright, and I've removed them.
I see you can get 39mm led's which have fewer elements, which may be not so bright, so I may give them a try.
