Blow off valve 1.8t anyone?
  • Thread starter Deleted member 137012
  • Start date
D
Guest
Anyone here running a BOV on a 1.8?
Mrc5z
Brick, NJ
Most people are not.
I had one of those DV spacers for a hot minute, found it to be annoying after a while. VW uses the factory diverter to bleed off boost as well so you would hear the noise even when not fully off throttle. Lost the factory spring during install/re-install so I bought a GFB DV+, offers a bit more noise than the OEM unit I think. Opening up the intake would produce the same sound.
Any particular reason you want one?
Sparky589
Yeah the stock diverter valve is a very robust unit, there really isn't any meaningful reason to replace it with an aftermarket solution. If noise is what you're after I would recommend a spacer, but keep in mind if you're running a manual it can get a little excessive when it comes to noise.
For what it's worth I know Mrc isn't alone in his opinion, Melted Solid who also drives a 5-spd wound up taking his unit back to stock because he couldn't stand the nonstop noise either.
However since the automatic is better able to keep boost through gear changes I literally don't hear my spacer unless I lift-off under boost. Personally this is perfect for me, I get no blow off whatsoever while putzing around but whenever monkey brain kicks in I can make it sound like a rally car.
MeltedSolid
San Francisco Bay Area
'15 Golf, e36 328i
at 10% throttle:
1st gear vroooooom PPPPPPSSSSSSSSSSSSSHHHHHHHHHH!!!! 2nd gear vroooooooooom PPPPPPSSSSSSSSSSHHHHHHHHHH!!!!! 3rd gear vrooooooooooooooom PPPPPPPPPSSSSSSSSSHHHHHHHHHHHH!!!!!.
Passenger: "Is your car steam powered?"
Faceman
Long Island
'17 GSW 4Mo
D
Guest
Yeah guys I ordered a CTS BOV for the sound! I want to have a bit of fun with the car, I don’t have an intake. No MAF, no risk of hurting the car?
Rogues Gambit
Eatontown, NJ
So, how are GFB DV+?
It's not the noise, just I figure I have one for my A4, and getting a IS20. I don't mind if it's overkill, I'd prefer that, and I know I won't get the "Pshh!", just would it be detrimental with how good stock is
George Smooth
South Africa
Strange this was posted. We get at least one email a day with guys that want Pshhhhh pshhhh so we developed a spacer for this that will be cheapest on the market and should be out in the next three weeks.
D
Guest
So much confusion with the BOV, Paul from shop dap said it’s fine but forum scientists say it’s bad
Jovian
Denver, CO
2016 VW GTI
Part of the issue is all previous generations used a MAF sensor. Now we don’t have one so venting to atmosphere isn’t a big deal.
Problem now is how active the venting is, it can be very annoying. I suggest a spacer and use the stock DV as it’s cheaper option.
D
Guest
How annoying is it on an auto? I want cool sounds (I’m 20) but it is so nagging that I’ll take it off eventually?
Sparky589
You'll be totally fine on an auto, it's really on the manual transmissions that it becomes unbearable.
D
Guest
Cool man, I see horror stories about people getting oil in their engine bay and that kinda shit lol. I’ll throw it on once I get it
MeltedSolid
'15 Golf, e36 328i
Oohh. Well for what it's worth, my spacer was super open with giant holes on all sides, which I think contributed to the excessive noise. Sparky's has a much smaller hole and it makes a rally-BOV-whistle style noise when it activates, which I like much better.
