I'm trying to figure out what exactly the OE Mk7 fluid is. Part is G 052 145 S2. I assume any API GL-5 75w90 gear oil would work, but if you google the part number, you get results matching Castrol Syntrax Long life, Fuchs Sintopoid, Motul Gear 300 (two GL-5 oils and a dual-rated GL-4/GL-5).
The odd thing is if you look up a Mk7 R on various manufacture's sites, you get some different results. Motul recommends Gear 300 LS (limited slip additive), Liquimoly suggests MTF 75w90 (GL-4), Redline recommends MT-90 75w90 (GL-4) and AMSOil, their Severe Gear 75w-90 (GL-5). The same fluid is in the rear differential, which definitely isn't a limited slip stock.
I think I've also seen folks like @tigeo run LM GL4+ or Redline 75w90NS, but neither of those are approved or recommended. Anyone know if GL-4 or GL-5 is preferred, and whether you'd want limited slip additive in a bevel box?
