edward@becautoparts.com
- Vancouver, BC
Here is the install guide for the new BEC/DMC LED Tail Light Adapters.
So you recently purchased a set of LED Tail lights or adapters from BEC Autoparts, and you want to know how to plug in the adapters. Here is the guide.
This version of the adapters have been shipping since mid-March 2016.
NOTES - Install and coding is different than the DAP Adapters, do not follow the DAP guide for these adapters. It will not work.
You get 4 wire harnesses, there are left and right sides. The right inner tail light has a black wire.
Left Outer Tail Light Adapter
Left Inner Tail Light Adapter
Right Inner Tail Light Adapter
Right Outer Tail Light Adapter
Diagram Showing Wire Layout
Coding Instructions:
If you purchased our tail lights or adapters, you will get a full set of coding instructions in PDF format as well as a hard copy.
IMPORTANT NOTE FOR MY2015.5 AND EARLIER:
I believe sometime around mid-2015, the channel for rear side-marker lights changed from Leuchte26NSL to Leuchte27NSL. On our test MY2016 NAR Golf 7R, it was Leuchte27NSL. Check your original adaptation channels if you are unsure. If your vehicle uses Leuchte26NSL, make the above changes to the appropriate channels under the Leuchte26NSL set.
