BBK Kits
MarkGTI
Missouri, US
I've been looking into BBKs recently and there's 2 that have caught my attention, the VWR BBK that sells for $2749 and the ECS Porsche BBK that sells for $2249. They are both 6-pot 352x32 and I don't know what makes the VWR so much more expensive and which one to get. Any feedback or reply would be great.
the bruce
land
Golf GTI Mk.V 2008
Get the VWR, as the ECS/Porsche's piston sizes probably do not fit the Golf's master cylinder !!
Same issue as on the Mk.V and Mk.VI:
http://www.golfmk6.com/forums/showthread.php?t=48777
http://www.golfmkv.com/forums/showthread.php?t=175147
the bruce
land
Golf GTI Mk.V 2008
They claim it to do does not mean it really fits perfectly. I'd wish ECS
(and all the other vendors) in general would publish the piston sizes.
These need to have a total piston area similar to or slightly smaller
than the stock caliper's single piston to provide same pedal travel +
improved pedal feel.
The only OE Porsche calipers that do fit a 22 or 23.6 mm MC are the
Cayman and Boxster 986 calipers.
Keep in mind some safety features like ESC and brake assistant are
negatively affected by altered pedal travel.
MarkGTI
Missouri, US
so VWR is definitely the way to go with this one?
the bruce
land
Golf GTI Mk.V 2008
At least the (Caparo AP made*) VWR caliper is specifically designed to the Golf
with its FN3 (54 mm piston) and FNRG (57 mm) calipers and 22/23.6 mm MC in
mind.
Because there are plenty of kits available for Mk.V and Mk.VI there might come
some more suitable BBKs from AP Racing, Brembo, Tarox, Alcon and others, but
you cannot go wrong with the VWR kit.
Another idea is to wait for the Brembo BBK, which is now available as a factory
option for the new GTI/R sibling named Seat Leon Cupra. This BBK seems to be
similar to the former RS3/TT-S 4-pot 370x32 mm front brakes, but modified to
fit the current MQB platform. Probably not on a par with the more expensive
aftermarket BBK regarding pad size and rotor quality, but it's OE and reliable for
winter use. In particular Chines BBKs don't like to be exposed to salt and water.
As standard the Leon Cupra comes fitted with the same 340x30 mm FNRG front brakes as both the
Golf R and GTI w/ Performance pack. Front swivels/hubs are the same as well on all three hatches.
So perfect fitment guaranteed.
btw, another nice factory option are the Michelin Pilot Sport Cup 2 R-compounds !!
* not related to AP Racing, who are also based in Britain
snsd555
Singapore
i've heard that VWR will be launching a new BBK for the MQB platform soon. not sure how accurate just might be something to keep in mind.
cheers!
the bruce
land
Golf GTI Mk.V 2008
Part numbers of that coming soon Cupra Performance pack factory option Brembo BBK:
5F0 073 910 Festsattelbremse rot links
5F0 073 910 A Festsattelbremse rot rechts
5F0 073 910 B Festsattelbremse schwarz links
5F0 073 910 C Festsattelbremse schwarz rechts
2x 8A0 615 273 Entluefterventil und Staubkappe
4x N 105 103 01 Innensechsrund-Zylinderschraube
4x 8J0 615 431 Tilgergewicht
8J0 615 133 Halter links
8J0 615 134 Halter rechts
8J0 615 301 F Bremsscheibe (belueftet)
8J0 698 151 K 1 Satz Bremsbelaege fuer Scheibenbremse
8J0 615 437 Kontaktgeber
5F0 073 911 Hitzeschild links
5F0 073 911 A Hitzeschild rechts
4x N 908 768 02 Sechskantbundschraube (Kombi)
2x 5F0 073 912 Bremsschlauch
8J0 611 841 D Halter fuer Bremsschlauch links
8J0 611 842 D Halter fuer Bremsschlauch rechts
~ 2500€
buddyg
Paris
Do you really think, we need to buy all the spare parts ?
Or juste th Disk, Brake should be enought to switch to our car ?
the bruce
land
Golf GTI Mk.V 2008
Rotors and calipers are by far the most costly. The rest is peanuts.
At the very least you'd also need brackets ("Halter"), pads ("Bremsbeläge"), bleeder
valves ("Entlüfterventil") and hoses ("Bremsschlauch"), and probably some hardware.
To make it short and simple - get the complete stuff. ;)
Just the heat shields ("Hitzeschild") aren't essential, particularly not for track junkies, who
need all ventilation available. In such cases I stringently recommend to fit the TT-RS air guides
bolted to the lower control arms. Cheap and easy mod.
RjRacing
Philly
The biggest problem with the TT-S/RS3/Rear R8 brake upgrade is that if you track the car one rotor gets hot much faster than the other becuase the rotor veins vent air in the same direction for either side. If your just doing street driving this is fine, but after a 20 minute track session your car will be pulling to one side.
For the money I would suggest VWR BBK as the best option out right now.
the bruce
land
Golf GTI Mk.V 2008
Another two points:
1. The Cupra Performance Pack calipers have 40 + 44 mm pistons
- not ideal for stock master cylinder, requires specific ABS application
2. The new Audi TTS "8S" comes with "small" fixed caliper brakes, consisting of:
338 x 30 mm rotors + 4-pot calipers
This kit could be an OE option for those who think they don't need
oversized 355 or 370 mm rotors and/or still want to run 17" wheels.
TecklenburgVW
Saint Cloud, FL
Bruce, when you have a moment, could you post the part numbers for the left and right TT-RS air guides?
Thanks!
the bruce
land
Golf GTI Mk.V 2008
vent 8P0 863 149 A and 150A - about 15 € in Europe
bolt 2x N104 222 03
nut 2x N 907 611 02
tube 2x 8J0 864 133 A
if you want add this:
aluminium dust shield 8J0 615 311 E and 312E - about 25 €
http://www.golfmkv.com/forums/showthread.php?t=167216
http://www.golfmkv.com/forums/showthread.php?t=163575
Depending on your current control arms some trimming may be required.
I didn't try the on the Mk.VII control arms, and I most probably won't,
as I plan to fit the Audi TT 8S aluminium control arms (lighter, stiffer,
better bushings), which most probably will match the vents without any
modification. Trimming a plastic wing is quite easy anyway.
