This mod improves the throttle response by changing the engine branding from "VW/Seat/Skoda" to "Audi". In my opinion it's the best performance mod you can make one step short of remapping. Research shows that some drivers who've made this mod on other MQB platforms (Golf Mk7 from memory) report some errors in the dashboard.I test my Passat B8 and my friend's SuperB,it really made the different.
VCDS:
Select 01-Engine
Enter Long Coding and change the first byte from 01 to 02 (i.e. uncheck bit 1 and check bit 1)
You will probably receive any error message in the instrument cluster - this is OK. Just cycle the ignition and away you go!
VCDS:
Select 01-Engine
