Audi aluminum subframe on Mk7 Gti
A3SBQ
Norway
Does anyone know the part number for the longer bolt needed to attach control arms to the Audi subframe?
Thanks.
Dud. Check out the links provided over
A3SBQ
Norway
Ahh. Ok.
No worries. Didn't mean to come off hard. Was on a rush and couldn't write a better sentence ��
The part no for the two washers are WHT 006 844
For the bolts it is N 107 854 01
Mind you. I did not install my setup yet. So can't confirm correct fitment.
This is the parts my shop sold to me.
supesgolfr
The Net
Ahh. Ok.
Thanks! And do I need 2 or 4 bolts? (sorry to be a dummy about this).
A3SBQ
Norway
Good question! Don't remember how many was in the bag!
Now I feel a bit dumb!
Some one here can help?
supesgolfr
The Net
I did the subframe after I did the control arms. The front end feels a bit stiffer (not as much flex) since I changed to the aluminum subframe.
May I ask how you are able to tell that the front end feels "a bit stiffer"?
For example, when changing to poly bushings on the control arms, the feeling you get is increased road feel, so your hands feels the vibrations of the road more. But when someone says "the front end feels a bit stiffer" - I can't imagine what this feels like, and how one is able to measure the difference before and after.
Thanks!
TXRanger83
Midland, TX
Going to be placing an order soon and it looks like all that is needed is:
subframe 5Q0199369G (x1)
washers WHT006844 (x2)
bolts N10785401 (x4)
anybody know of any additional parts needed for this install?
St. Olaf
Sadly 'LeGTI's pics aren't working anymore, however I updoaded
them again since I think they're way too beautiful to hide: ;)
A3SBQ
Norway
How is your setup holding up?
Did my full install last week.
I noticed a scweek after the installation that has gone away. Do you still need to retight all bolts?
I have new bolts and washers...
Mars1
South FL
Unfortunately I hit a pothole, blew out a tire and came to find I also slightly bent the stamped subframe.
I'm thinking of doing this A3 subframe install myself. Can anyone share some insight as to whether I need the VAG "locating pin" tool numbers T10096 and T10486/1 or /2 to reinstall the new subframe correct and centered/square?
The manual says to use all 4 pins first, then remove and install the bolts one at a time.
http://workshop-manuals.com/volkswa..._shafts/subframe/fixing_position_of_subframe/
Thanks for any heads up or info on this swap guys. Some details from the Golf manual-
