Well, I'll conclude this thread for now by summarizing my thoughts on the APR stage 1 tune now that I had to downgrade, and have used my JB4 in Map 0 to monitor/log how it works and now even "stacking" a bit with Map 6. Keep in mind I should be trading this in or selling it in about 6 weeks
So, now on Stage 1 IS12 91 octane, I accidently had my JB4 set to 20psi for my fail safe, after I set it to 25 the APR tune is peaking at a full 22.1psi on a 91 tune, which surprised me a bit for that low of octane. Even running Map 0 for logging/monitoring, that lower section of options below the boost curve settings apply to map 0 too and I had forgot about that. If I was keeping this car, I'd get the intercooler and charge pipes I have siting here installed, IAT's can get out of control with APR when it's not cold out. But, also, for a straight up flash tune, Unitronic still sells a Stage 2 that is better than this that I could run, but with my intake mods and DP it at least maxes out the APR stage 1 nicely. It's *really* punchy, in D mode when you give it that good 1/4 throttle to get it to kick down, it really jumps out. I know I'm easily making the 285lb/ft the stage 1 claims, maybe a little more with stage 2 mods. I tried to get some 0-60 and 1/4mile with my Dragy, it was just too cold and damp and got no traction but I'll practice launches until it gets traded in, hehe. The APR tune does allow brake boosting, so it's prob possible to launch this pretty good with good traction, but I don't want to break it before I trade it in. But as far as that peak boost, it doesn't last long and starts tapering off pretty fast after 4500RPM, all the way down to 8psi by 6300RPM, but they do progressively add a nice amount of timing, up to about 22 degrees up top it looks like, to keep you pulling pretty smooth all the way to the 6500 shift point while keeping the throttle buried on the 09G. To that end, I felt that the boost dropped a little bit too much at the top, and I have "near 93" underrated 92 octane here, so I figured I'd try a simple additive Map 6 stack. I kept all the fuel stuff at 0 and just added 1psi from 1500 up to 5500 and from there added 2psi from 5500-6500 to help it keep pulling to the shift point. Even with this just 1psi added down low, light throttle response under D mode is improved and it does pull stronger up top too. Trims never exceed mid 30's, AFR's look great. If I was keeping the car, I'd continue to stack when I have decent fuel, but would be getting the IC and charge pipes in by summer as IAT's climb pretty quick with that much boost.
So, bottom-line as far as this thread, it looks like I got an IS20 with a WGA that was already ready to fail or something so once it did go completely I was never able to determine my probs with the IS20 stage 3 tune were, who knows, a fresh WGA maybe could have fixed the issue or do nothing at all to help. We'll never know as I was tried of dealing with it, I had to get back on the road that day. Otherwise I could have had a machine shop get that screw out or get another IS20 from LKQ for $375 and tried to make the IS20 setup work. But, at the same time, I found out I can get a MK8 GTI for no markup and able to fit it into my budget sealed the deal. A waste of ~$1500 to end up back on stock turbo and with a real flash tune that has enough power to be happy with for a while that I could have had all along... sigh.
