GTI Jake
- Charlotte, NC
The dampers in my video were "like new" (to me) after ~45K or whatever it was with half of that on H&Rs. Stock dampers are probably running at reduced rate on stock springs a lot sooner than folks realize. Linear or not should have no bearing on that. These APR springs are working as a single-rate linear spring most of the time, it's not like they are continuously progressive...it's just 2 rates....1 you are in all the time, and 1 for the dead coils that you only "see" when you are at full extension. Unless oil is leaking out, I can't see how a damper "wears out"...the orifice the oil flows through doesn't get wider..hahaha
Oil does break down, in a shock just like in a drivetrain component.
So thinned out oil, going through that same size orifice is in fact in a way “wearing out”, just not in the way you might think.
Some suspension is also gas charged as well, and once the gas leaks out due to worn seals the performance is drastically reduced.
Be it from lost nitrogen charge, thinner viscosity shock oil or both, reduced valve dampening on an already over sprung set up will snowball once the degradation begins.
