Ezekiel81923
- Royersford, PA
- 2019 Volkswagen GTI
People use these half-asssed solutions because of EXACTLY what Klrider44 said... they don't want to drop their subframe and they don't have any experience with better than mediocre solutions to compare to so they listen to the next guy with the same story. It's the EXACT same reason 90% of MK7 owners only have a RSB (minus the autocross guys).
New to GTI's so maybe I need to do more homework, but...
Is the only way to replace the upper part of the stock bushing to drop the subframe? I'm not clear on what dropping the subframe gains us access to.
On my old car the rear motor mounts / dogbones were much easier to get to, and the aftermarket solutions were solid arms and replacement, heavy duro bushings (mine was 88 duro, NVH FTW). Most of what I see for the GTI's is bushing inserts that would seem ineffective and fairly chinsy arms compared to what I had on my Speed. My line of thought is if it doesn't add any NVH than how much stiffer could it be than what you just took off? But I've also gathered that I'm less NVH averse than a lot of people on this forum (nothing but love to you all).
I was going to go with the Racingline mount because it appeared to be the most solid and most complete looking solution but if I can't just crawl under there and swap it out then I understand where the pain is coming from.
