Norsk982
- MALVERN, PA
Love my Michelin Pilot Sport AS3+, way better than the DWS06 I had before.
Don't see why not.
Neither do I, just wanted to confirm with the folks on here that had the tires.
Replace all 4 with like tires or replaced the two bad ones with the same you already have on the car.I’m not sure if it is safe to do, but the Bridgestone potenzas on my car don’t have so much life left in them, after a summer of “spirited driving” and couple drag strip days. No burnouts. But the rear ones are perfect only 6800 miles. Could I swap out just the front for Michelin? Same size.
Except the same can happen in the rain or even in the dry (if you fully read my post)Just stay home when it snows... problem solved
If you need to drive in the snow, definitely invest in a separate set of wheel\ties
It's NEVER recommend to use different tires front and rear.
I agree with you on that.I agree, however if your front tires are worn a bit more then your rear, I do not see a problem with rotating the tires to even out the wear. Unless the difference is drastic.
BTW that was a good video, thanks for sharing!
Looking at these tire as well and curious what size tire to use on 18x8.5 rims... 235 or 245 ?
