I'm a bit confused - looking for clarification.
H&R lists the same part # (28851-11) for both Golf and GTI applications. They also list the drop as 1.5" - 2.3" up front and 1.1" - 2.0" in the rear.
Currently I'm on VWR springs and stock dampers and about 1.2" down - perfect drop, IMO, and with the wheels I run (RSe10's in 18x8.5 and Michelin PSS in 235/40R18, I had the tiniest bit of rub at full travel - fixed it by doing the screw mod. Ride's rough for a number of reasons - stiff sidewalls, lowering springs and stock dampers (and I don't care who says VWR matched these to the OE dampers, on some roads I pogo like a cracked out clown).
I reached out to a respected member here and asked something along the lines of:
Hey, the car's a DD w/ MAYBE 5% tracktime, so I'm after a modest drop not to exceed the drop I've already got - can you recommend a coilover? Looking Bilstein B16's, H&R Street Performance or KW Street Comfort".
He recommended the H&Rs.
Now for a little math and assumptions.
If we assume H&R is talking ride height up front at 1.5" on a GOLF, that's a 38.1mm drop initially.
If you take the 15mm the GTI rides lower than the Golf, then the drop should be / may be / could be the difference between the two - in other words you end up with an overall drop on a GTI of MINUS the 15mm the GTI's already lower, for a 23mm minimum drop on a GTI.
That's about .9 inches and would totally work, I could actually wrench them down a bit to get back to my 30mm / 1.2" current low over stock.
So does anyone actually run these coilovers and have stock fender to ground and post-install fender to ground measurements to back my theory up with facts?
Again, the car's a DD and I don't give a sh*t about ZOMG SO LOW, I want comfortable riding lowering with the benefits coilovers bring to the party.
Much appreciated!
Much appreciated!
