Goodmorning,
I have a question and some information I would like to share.
I have found a 5q0980568a camera which is same as the one in car of mr-fix, that he bought second hand. Is there someone who knows where to find dataset for this version? Or is there someone who knows if it is possible to flash with 5Q0980568B V250 and use dataset found on MIB solutions. Hope to receive camera next week.
Furthermore,
I still have no succes with calibrating the 5q0980556b camera. Although I think I'm doing the right things, it seems impossible. I am using Dataset for Passat B8 Variant. Calibration I do with Odis S. I figured the most important values are:
-Wheel base + distance to board (for Golf 7 2626 + 1500 = 4126).
-Board size (Full size in my case).
-Hight of marker (because of "floating guidelines") I think it must be around "-160" (Yes, minus).
-You can play with hight of camera and hight of wheel arch, but this seems only when you are to far out of spec that it influence calibration. If left on "0", I get same results.
The reason I think I'm doing the right thing, is that if I use values to far of as described above , I get the error "calibration board not found". But if I stay not to far of, I get "position calibrationboard wrong". Also I get readings which actually visually influence the guidelines, which are almost in sinc now. But basic settings error remains since there is no successful calibration. If you have doubts about this, I can read those values in OBD11 afterwards, where there are otherwise only zero's, so readings are saved in module.
I tried calibration based on detected car, but also manually picked Passat B8, before calibration, this seems not to do anything, since I get exactly same results.
For that reason I now continue my journey with another type of cam wich I found cheap.
Greets Chris
