I don't have Android auto in my 2015 but the BT audio quality while using Spotify is excellent. I was shocked the first time I played something. Much of it may depend on your particular phone.
Yup. I download all the songs onto my phone(microSD) that's on Spotify and set the download quality to extreme, then play via bt. Sound is great and I'm surprised how it gets the oem fender sub moving.If you're streaming through Spotify, you're only streaming at 160/320 kbps regardless. That's going to be the lowest common denominator in the quality equation.
Sent from my ONEPLUS A6013 using Tapatalk
The phone does make a difference.The phone itself does make a difference. LG phones are known for their high quality DACs.
okay, let's see if we can improve the quality of AA sound
Here's the part of the gal.json config file in the MIB2 High:
Code:"audio":{ "source":{ "dump":{ # activate audio source dumping by setting "enabled" to "true", otherwise "false" #asodump !! don't remove that marker and always keep it before the "enabled":x, line! "enabled":false, "maxFiles":50, # maximum size per dump file in bytes (multiply by maxFiles for maximum dump space occupied) "maxFileSize":2097152 }, "samplingRate":16000, "bits":16, "channels":1, "nvaudio":{ # options: "ENT1", "SSE_REC", "MIC" "device":"MIC3" }, "asound":{ "device":"mic1", "pluginAware":true, "startMode":1, "stopMode":1, "fragsMin":3, "fragsMax":5 } }, "sink":{ "dump":{ # activate audio sink dumping by setting "enabled" to "true", otherwise "false" #asidump !! don't remove that marker and always keep it before the "enabled":x, line! "enabled":false, "maxFiles":50, # maximum size per dump file in bytes (multiply by maxFiles for maximum dump space occupied) "maxFileSize":2097152 }, "media":{ "freq":48000, "bits":16, "channels":2, # See enum MediaCodecType in protos.pb.h "codecType":1, "maxUnackedFrames":16, "nvaudio":{ # options: "MPL6", "MPL1", "MPL5" "device":"MPL6" }, "asound":{ "device":"mpl1_int_ent", "pluginAware":true, # DATA=1, FULL=2, GO=3 "startMode":1, # STOP=1, ROLLOVER=2 "stopMode":1, "fragsMin":3, "fragsMax":5 }, "renderer":{ # Delay in microseconds until retry is performed if the route is unavailable "retryDelay":50000, # Max. number of retries if the route is unavailable (0 to disable the retry mechanism) "retryCount":3, # Number of frames to be buffered before the playback starts or 0 to disable buffering "framesBufferedMin":4, "framesBufferedMax":6 } }, # For an explanation of the parameters, see the "media" section "guidance":{ "freq":16000, "bits":16, "channels":1, "codecType":1, "maxUnackedFrames":8, "nvaudio":{ # PIN assignment: UI: "ANN5", Guidance: "ANN6", Voice/Telephony: "ANN7" "device":"ANN6" }, "asound":{ "device":"ann1_int_nav", "pluginAware":true, "startMode":1, "stopMode":1, "fragsMin":3, "fragsMax":5 }, "renderer":{ "retryDelay":50000, "retryCount":3, "framesBufferedMin":4, "framesBufferedMax":6 } }, "decoder":{ "decodeBufferSize":1048576 } }
I think we can try to increase the sampling rates and frequencies? At least, switching to a depth of 24 bit could improve the sound a little, although I highly doubt Bluetooth audio has such a high dept.
When using same codec with two different phones, would there still be a difference since Bluetooth is digital?The phone does make a difference.
You are correct, the DAC on LG phones is great - but that only applies if using appropriate headphones.
Bluetooth varies from phone to phone.
Sent from my Pixel 3a using Tapatalk
I don't see the point of using my phone for music when I can have a 32gb SD card in there all the time.
No, I got this from the filesystem of the MIB2, which you cannot reach over OBD.Did you access this with OBDeleven?
How did you access it? I want to try a few mods to reduce my Android Auto volume or add more volume steps.No, I got this from the filesystem of the MIB2, which you cannot reach over OBD.
I'm going to test this with a friend who uses Tidal, and set it to 96Khz
Is anyone able to use any Bluetooth codec other than SBC under developer options?
I have access to the file system of the unit through the developer debug console. It's not for the faint of heart however
I don't think there's a setting regarding volume steps in the AA volume. But... can you check if you have an Android Auto / Google Automotive Link green menu screen somewhere in the mmx section? If so, some versions have a "replace GAL" or "replace Google Automotive Link" screen. That would allow us to replace the config file by one from SDcard and would make life a little easier.
I also using viper4a. If you go the settings and select compatible mode then skip to the next song, it'll processing for AA. The sound is as good as playing through Bluetooth.To me its the same. Quality over BT is better than via Android Auto. Though for me the answer is simple. I use ViPER4Android, a popular equalizer for rooted phones, and the app controls all devices (hardwired included), but it does not seem to work for me via Android Auto.
So quality is always better for me via Bluetooth because the equalizer actually makes a difference for it.
Sent from my Pixel 2 XL using Tapatalk
Where is the mmx section? Is that part of the green engineering menu?
