Darren barker
- Bolton
- Golf r mk7
I have a golf r 2014 mk7
I have had lights pop up on dash all at once and they staying on.
Acc
Airbag
Abs
Handbrake
Engine management
Stability
And a few more I have had a vw engineer look and to put his Computer on it . I will post the full code report of my car below. It says no comms to airbag module. Could all these faults becased but this ? Thanks
Wednesday,11,October,2023,10:00:42:45427
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 23.3.1.0 HEX-V2 CB: 0.4631.4
Data version: 20230421 DS346.2
www.Ross-Tech.com
Dealer/Shop Name: KING OF THE ROAD
Workshop Code: 640 01514 000003
VIN: WVWZZZAUZFW058729 License Plate: R400DBC
Mileage: 105126km-65322mi Repair Order: FAULT SCAN
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 22 42 44 47 52 55 5F A9
VIN: WVWZZZAUZFW058729 Mileage: 105126km-65322miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: Cannot be reached 0100
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
22-AWD -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
47-Sound System -- Status: Cannot be reached 0100
52-Door Elect, Pass. -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
5F-Information Electr. -- Status: Malfunction 0010
A9-Struct. Borne Sound -- Status: OK 0000
Address 01: Engine (J623-CJXC) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 E HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0003
Revision: --H13--- CVN: D0AAEAE2
Coding: 091D00322466050B2004
Shop #: WSC 01357 011 00200
ASAM Dataset: EV_ECM20TFS0205G0906259E 001003
ROD: EV_ECM20TFS0205G0906259E_VW37.rod
VCID: 3038EB321AA844BABFB-8064
VINID: 9E69EAAAA465A969C01481C224DF82D7CB
11 Faults Found:
20638 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
P0036 00 [175] - Malfunction / Open Circuit
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 2
Mileage: 105099 km
Date: 2023.09.09
Time: 13:46:34
Engine RPM: 1456.75 /min
Normed load value: 8.2 %
Vehicle speed: 0 km/h
Coolant temperature: 11 °C
Intake air temperature: 13 °C
Ambient air pressure: 980 mbar
Voltage terminal 30: 11.406 V
Unlearning counter according OBD: 40
Engine: operating status: IS
STATE_LS_SAE[1]: OL_CDN
T_AST_SAE: 0 s
MAP_MES_SAE: 48 kPa
VLS_DOWN_SAE[1]: 1.275 V
Lambda probe heater: resistance: bank 1: probe 2: 65535 Ohm
TEG_DYN_LS_DOWN[1]: 12.8500 °C
20636 - Oxygen (Lambda) Sensor B1 S2
P0138 00 [032] - Signal too High
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 105099 km
Date: 2023.09.09
Time: 12:40:54
Engine RPM: 905.50 /min
Normed load value: 6.7 %
Coolant temperature: 92 °C
Intake air temperature: 40 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 13.242 V
Unlearning counter according OBD: 33
STATE_LS_SAE[1]: CL
T_AST_SAE: 3660 s
MAP_MES_SAE: 46 kPa
VLS_DOWN_SAE[1]: 0.000 V
Lambda probe heater: resistance: bank 1: probe 2: 69 Ohm
TEG_DYN_LS_DOWN[1]: 429.7250 °C
17178 - Implausible Data Received from ESP Control Module
U0416 00 [032] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 105099 km
Date: 2023.09.09
Time: 13:49:56
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Coolant temperature: 97 °C
Intake air temperature: 62 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 12.167 V
Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
Drivetrain coordinator: brake fault status-Deceleration sensor not available: No
Drivetrain coordinator: brake fault status-Deceleration sensor malfunction: No
Drivetrain coordinator: brake fault status-ESP system error: No
Drivetrain coordinator: brake fault status-ESP system malfunction due to inaccurate engine torque: No
Drivetrain coordinator: brake fault status-ESP indicates TSK message consistency error: No
Drivetrain coordinator: brake fault status-TSK/ESP handshake error: No
Drivetrain coordinator: brake fault status-ESP automatic engagement malfunction: No
Drivetrain coordinator: brake fault status-Brake light implausible: No
20640 - Oxygen (Lambda) Sensor B1 S2; Heating Circuit
P0141 00 [101] - Malfunction
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 105099 km
Date: 2023.09.09
Time: 13:50:56
Engine RPM: 854.00 /min
Normed load value: 7.5 %
Coolant temperature: 91 °C
Intake air temperature: 65 °C
Voltage terminal 30: 13.164 V
Engine: operating status: PL
STATE_LS_SAE[1]: CL
T_AST_SAE: 59 s
MAP_MES_SAE: 53 kPa
VLS_DOWN_SAE[1]: 1.190 V
Lambda probe heater: resistance: bank 1: probe 2: 18514 Ohm
TEG_DYN_LS_DOWN[1]: 620.0375 °C
15288 - Starter Relay 1
P26F0 00 [096] - Stuck Closed
15296 - Starter Control; Returned Message
P3052 00 [032] - 50 Short to Plus
15282 - Engine Starter Malfunction
P06E9 00 [032] - -
19846 - No Communications with Airbag Control Module
U0151 00 [047] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Mileage: 103166 km
Date: 2023.04.17
Time: 16:09:15
Coolant temperature: 95 °C
Intake air temperature: 66 °C
Ambient air pressure: 1030 mbar
Voltage terminal 30: 11.933 V
Engine: operating status: ES
ECU_STATE: ENG_STOP
Engine oil temperature: 103.0 °C
Time since engine start: 0.0 s
T_ES: 6 min
Cruise control switch actuation-Main switch: Not operated
Cruise control switch actuation-Set: Not operated
Cruise control switch actuation-Resume: Not operated
Cruise control switch actuation-Status: OK
Cruise control switch actuation-Accelerate: Not operated
Cruise control switch actuation-DELAY: Not operated
Cruise control switch actuation-Cancel: Not operated
Cruise control switch actuation-Main switch hardware: Not operated
Cruise control switch actuation-Coding: plausible
Cruise control switch actuation-Limit function: not selected
Cruise control switch actuation-Limit button: Not operated
Cruise control switch actuation-Main switch CAN: Not operated
Cruise control switch actuation-Large increment: Not operated
Cruise control switch actuation-Control component verified: Yes
STATE_ERR_ABC_PRED: 0
22057 - No Communications with Parking Assist Control Module A
U0159 00 [032] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Mileage: 105067 km
Date: 2023.08.26
Time: 17:08:55
Engine RPM: 1206.00 /min
Normed load value: 8.6 %
Intake air temperature: 12 °C
Voltage terminal 30: 14.394 V
Unlearning counter according OBD: 37
ECU_STATE: SYN_ENG_IGK_ON
Engine oil temperature: 10.0 °C
Time since engine start: 5.7 s
T_ES: 0 min
STATE_ERR_ABC_PRED: 18
21323 - Implausible Data Received from ABS Control Module
U0415 00 [032] - -
[Invalid Data Received FromAnti-Lock Brake System Control Module]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 105099 km
Date: 2023.09.09
Time: 13:45:09
Engine RPM: 895.25 /min
Normed load value: 6.3 %
Intake air temperature: 54 °C
Voltage terminal 30: 13.476 V
Engine oil temperature: 104.0 °C
Time since engine start: 6553.5 s
T_ES: 0 min
STATE_ERR_ABC_PRED: 5
23131 - Implausible Data Received from ABS Control Module
U0415 00 [032] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 105099 km
Date: 2023.09.09
Time: 13:45:09
Engine RPM: 891.25 /min
Voltage terminal 30: 13.515 V
T_ES: 0 min
Readiness: 0010 0001
Address 02: Auto Trans (J743) Labels: 0D9-927-770.clb
Part No SW: 0D9 300 012 L HW: 02E 927 770 AQ
Component: DQ250-6A MQB H52 4932
Revision: 05852204 Serial number: TFK01406300964 CVN: 00000186
Coding: 0014
ASAM Dataset: EV_TCMDQ250021 001001
ROD: EV_TCMDQ250021.rod
VCID: 1F1A188E7736CBC2161-804A
1 Fault Found:
10657 - RPM Signal from ECU
P0726 00 [002] - Implausible Signal
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 907 379 M HW: 5Q0 907 379 H
Component: ESC H31 0571
Revision: 00000000 Serial number: 61934000000399
Coding: 01FA93A154252974037E070241CC6980C92A94C0E08296F7F8425078C208
ASAM Dataset: EV_Brake1UDSContiMK100IPB 033001
ROD: EV_Brake1UDSContiMK100IPB_033_VW37.rod
VCID: 46D4ADEA882CFA0A757-8012
8 Faults Found:
0095 - Rear Right Wheel Speed Sensor
C101D 29 [008] - Signal Implausible
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 231
Mileage: 103536 km
Date: 2023.05.06
Time: 20:32:24
0297 - Steering angle sensor
B1168 16 [008] - Voltage Too Low
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 157
Mileage: 103166 km
Date: 2023.04.17
Time: 00:00:23
8200 - Databus
U1121 00 [009] - Missing Message
[FCAN: Airbag_01 message is not received]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 254
Reset counter: 192
Mileage: 103166 km
Date: 2023.04.17
Time: 00:00:23
8204 - Databus
[FCAN: Airbag_02 message is not received]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 253
Reset counter: 192
Mileage: 103166 km
Date: 2023.04.17
Time: 00:00:23
8206 - Databus
[FCAN: Airbag_03 message is not received]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 95
Reset counter: 192
Mileage: 103166 km
Date: 2023.04.17
Time: 00:00:23
16390 - Display for Tire Pressure Monitoring
C1146 02 [008] - Signal Failure
Freeze Frame:
Fault Priority: 6
Fault Frequency: 6
Reset counter: 226
Mileage: 103166 km
Date: 2023.04.17
Time: 00:00:33
32869 - Databus
U1123 00 [137] - Received Error Message
[IPB-BUS: Airbag_02 / AB_Gurtschloss_FA invalid]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 117
Date: 2023.03.26
Time: 17:28:10
32994 - Control Module for Electric Parking Brake
C10E2 F0 [008] - RPM Sensor Implausble Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 230
Mileage: 103536 km
Date: 2023.05.06
Time: 20:32:24
Address 08: Auto HVAC (J255) Labels:| 5G0-907-044.clb
Part No SW: 5G0 907 044 AF HW: 5G0 907 044 AF
Component: Climatronic H03 0907
Revision: 00001K08
Coding: 00120004200100011005000000101000
ASAM Dataset: EV_ACClimaBHBVW37X 003018
ROD: EV_ACClimaBHBVW37X_003_VW37.rod
VCID: 6B823C5EF30EE762CA9-803E
Fresh air blower control module (front):
A/C pressure/coolant temperature sensor:
Air quality sensor:
1 Fault Found:
459009 - Databus
[Airbagsteuergerät - kein Signal/Kommunikation]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 117
Mileage: 103166 km
Date: 2023.04.17
Time: 16:09:12
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AJ HW: 5Q0 937 084 AJ
Component: BCM MQBAB H H18 0134
Serial number: 01011419702199 Dataset Number: 5G0063v____ 0001
Coding: 03001A42C24122F30BA44080B10C07281000000000000000000000000000
ASAM Dataset: EV_BCMCONTI 013000
ROD: EV_BCMBOSCH_013.rod
VCID: 00587BF2EA88143A0FB-8054
Wiper motor control module:
Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 140710 042 0551
Serial number: 140712031015
Coding: 0E4DDD
Rain/Light Recognition Sensor:
Subsystem 2 - Part No SW: 5Q0 955 547 A HW: 5Q0 955 547 A Labels: 5Q0-955-547.CLB
Component: RLHS 037 0059
Serial number: S5Y14M07D21H10M40S26
Coding: 00A8DD
Anti-theft alarm system sensor:
Subsystem 3 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY141613FX7
Alarm horn:
Subsystem 4 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000030238389
3 Faults Found:
528405 - Databus
[Airbag_01 Datenbus fehlende Botschaft]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 117
Mileage: 103166 km
Date: 2023.04.17
Time: 16:09:12
Terminal 15 status: On
Terminal 50 status: OFF
CAN-Bus_aktiv: On
Status Bremslichtschalter (HW): OFF
Status Bremslichtschalter (CAN): OFF
OFF: Not operated
Position lamps: Not operated
Automatic high beam assist: operated
Low beam: Not operated
Parking light left: Not operated
Parking light right: Not operated
last_wakeup: no cause for fault protection
Voltage: 12.0 V
Outside temperature: 21.5 °C
558101 - Databus
[Airbag_02 Datenbus fehlende Botschaft]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 117
Mileage: 103166 km
Date: 2023.04.17
Time: 16:09:12
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 12.0 V
934149 - Rain/Light Recognition Sensor
B1366 76 [008] - Incorrect Mounting Position
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 215
Mileage: 105061 km
Date: 2023.07.30
Time: 14:29:22
CAN-Bus_aktiv: On
OFF: Not operated
last_wakeup: gültiges Funktelegramm
Voltage: 13.1 V
Outside temperature: 19.0 °C
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 E HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0048
Revision: -------- Serial number: 39331419900416 Dataset Number: 5G0039v__A_ 0019
Coding: 0071051011
ASAM Dataset: EV_EPHVA18AU3700000 002024
ROD: EV_EPHVA18AU3700000_002_VW37.rod
VCID: 3D26C206DDFAB9D224D-8068
1 Fault Found:
13637426 - Databus
U1123 00 [008] - Received Error Message
[ESP - ESP_21.ESP_Systemstatus - Fehlerspeicher auslesen]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 226
Mileage: 105099 km
Date: 2023.09.09
Time: 13:45:09
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
Part No SW: 5Q0 907 572 D HW: 5Q0 907 572 D
Component: ACC Bosch MQB H05 0304
Serial number: 14071476510843 Dataset Number: 5g0114v____ 1018
Coding: 001C1300FE0739
ASAM Dataset: EV_ACCMRRBoschVW372 001015
ROD: EV_ACCMRRBoschVW372_VW26.rod
VCID: 3828D312F2D89CFAF7B-806C
9 Faults Found:
1067 - Brake Temperature
C10DF 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 226
Mileage: 105099 km
Date: 2023.09.09
Time: 13:45:09
Control Module temperature: 45 °C
Voltage terminal 15: 13.5 V
Vehicle speed: 0.00 m/s
Acceleration: 0.00 m/s²
1058 - Databus
[FAULT_CIS_ECD_NOTAVAILABLE]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 226
Mileage: 105099 km
Date: 2023.09.09
Time: 13:45:09
1059 - Databus
[FAULT_CIS_ESP_FAIL]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 226
Mileage: 105099 km
Date: 2023.09.09
Time: 13:45:09
Control Module temperature: 44 °C
Voltage terminal 15: 13.3 V
0283 - Databus
[FAULT_CIM_TIMEOUT_Airbag_02]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 117
Mileage: 103166 km
Date: 2023.04.17
Time: 16:09:12
Control Module temperature: 38 °C
Voltage terminal 15: 12.0 V
1043 - Automatic Distance Control
B10E7 F0 [009] - Disconnected
[FAULT_CIS_TSK_IRREV_FAIL]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 186
Mileage: 103166 km
Date: 2023.04.17
Time: 16:09:12
1083 - Databus
[FAULT_CIS_WHEEL_DIR_INVALID]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 226
Mileage: 105099 km
Date: 2023.09.09
Time: 13:45:09
Voltage terminal 15: 13.4 V
1118 - Databus
[FAULT_CIS_WHEEL_PULSE_FAIL]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 226
Mileage: 105099 km
Date: 2023.09.09
Time: 13:45:09
1081 - Databus
[FAULT_CIS_WHEEL_RPM_FAIL]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 226
Mileage: 105099 km
Date: 2023.09.09
Time: 13:45:09
1042 - Databus
[FAULT_CIS_WHEEL_RPM_PLAUS_FAIL]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 226
Mileage: 105099 km
Date: 2023.09.09
Time: 13:45:09
Address 15: Airbags
Cannot be reached
Address 16: Steering wheel (J527) Labels:| 5Q0-953-549.clb
Part No SW: 5Q0 953 507 DD HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 13071404401260
Coding: 0C10
ASAM Dataset: EV_SMLSKLOMQB 017001
ROD: EV_SMLSKLOMQB_017.rod
VCID: 7BA20C1E836E77E25A9-802E
No fault code found.
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 5G1 920 791 A HW: 5G1 920 791 A
Component: KOMBI 408 3196
Coding: 27AD40082F80260001886A011400000000000000
Shop #: WSC 00046 000 00000
ASAM Dataset: EV_DashBoardVDDMQBAB 009058
ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
VCID: 2A0CF95A3C743E6A71F-807E
1 Fault Found:
16776962 - Databus
[Airbag_01 keine Kommunikation]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 117
Mileage: 103166 km
Date: 2023.04.17
Time: 16:09:12
Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 T HW: 5Q0 907 530 F
Component: GW MQB High 128 1188
Revision: -------- Serial number: 0002263752 Dataset Number: 5G0067v____ 1821
Coding: 030100042B085900EF00027E1C0F00010001050000000000000000000000
GVL: 01D43C1000000000400C90000000C80000000000000000000000000000000000
ASAM Dataset: EV_GatewLear 011016
ROD: EV_GatewLear_011.rod
VCID: 42DCB1FAA404C62A59F-8016
Generator:
Multifunction steering wheel control module:
Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H10 0038
Serial number: 29140001488710054286
Coding: 2DFFFF
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 0386063903
4 Faults Found:
131594 - Parallel Parking Assistance Control Module
U104E 00 [008] - No communication
[Timeout Knoten 0x0A / 76 - Steuergerät für Parklenkassistent]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 227
Mileage: 105067 km
Date: 2023.08.26
Time: 17:09:01
Terminal 30 power supply: 11.6 V
Terminal 15: On
131605 - No Communications with Airbag Control Module
U0151 00 [009] - -
[Timeout Knoten 0x15 / 15 - Steuergerät für Airbag]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 117
Mileage: 103166 km
Date: 2023.04.17
Time: 16:09:13
Terminal 30 power supply: 11.9 V
Terminal 15: On
9175296 - Function Restriction due to Driver Fatigue Recognition
B130E 00 [008] - -
[Funktionseinschränkung Pausenempfehlung - Ausfall CAN-MSG Prio2]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 8
Reset counter: 200
Mileage: 103304 km
Date: 2023.05.06
Time: 10:04:03
Terminal 30 power supply: 13.0 V
Terminal 15: On
8526355 - Voltage Drop in Generator Leads too large
P30DE 00 [008] - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 150
Reset counter: 226
Mileage: 103229 km
Date: 2023.04.30
Time: 21:29:41
Terminal 30 power supply: 13.5 V
Terminal 15: On
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 D HW: 0CQ 525 130
Component: Haldex4Motion H52 7081
Serial number: HA1-00020.06.14 Dataset Number: v1260x015G0 0000
Coding: 0001
ASAM Dataset: EV_AllWheelContrHA1VW37X 002011
ROD: EV_AllWheelContrHA1VW37X.rod
1 Fault Found:
16656 - Databus
[Bremsensteuergerät - no speed signal]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 226
Mileage: 105099 km
Date: 2023.09.09
Time: 13:45:09
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 02071402090591 Dataset Number: 5G0222v____ 0058
Coding: 003F0220D001048000001000
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 40D8BBF2AA08D43A4FB-8014
Rear Driver Side Door Control Module:
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_DRV 005 0005
Serial number: 00000000000003260336
Coding: 1D0000
3 Faults Found:
65604 - Door Warning Lamp
B1326 01 [009] - Electrical Failure
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 117
Mileage: 103166 km
Date: 2023.04.17
Time: 16:09:12
458752 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 117
Mileage: 103166 km
Date: 2023.04.17
Time: 16:09:12
458857 - Databus
[RGS_VL_01 Datenbus fehlende Botschaft]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 117
Mileage: 103166 km
Date: 2023.04.17
Time: 16:09:12
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 3Q0 909 144 F HW: 3Q0 909 144 F
Component: EPS_MQB_ZFLS 503 5043
Dataset Number: 5G0074v____ 0452
Coding: 8103
ASAM Dataset: EV_SteerAssisMQB 010031
ROD: EV_SteerAssisMQB_010.rod
VCID: 3536DA26E5CA6192ECD-8060
2 Faults Found:
19716 - Databus
[ESP_10 Botschaft - SNA-Check]
Freeze Frame:
Fault Priority: 6
Reset counter: 226
Mileage: 103536 km
Date: 2023.05.06
Time: 20:32:24
Motor status: 02
System status: Driving mode
Supply voltage: 13.75 V
Temperature: 60.0 °C
KFC: 4D
KFA: 00 04
Freeze frame conditions: 20
uAdSensI_U1V2Filtered_gdu16: 1.20 V
uAdSensI_U5VFiltered_xdu16: 0.00000 V
uioUdNotFilt_xdu16: 14.00 V
uAdSensI_SwitchedKl30_xdu16: 13.98 V
ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
20228 - Databus
[ESP_19 Botschaft - SNA-Check]
Freeze Frame:
Fault Priority: 6
Reset counter: 226
Mileage: 105099 km
Date: 2023.09.09
Time: 13:45:10
Motor status: 01
Supply voltage: 13.50 V
Temperature: 73.0 °C
KFC: 4F
KFA: 00 04
Freeze frame conditions: 21
uioUdNotFilt_xdu16: 13.70 V
uAdSensI_SwitchedKl30_xdu16: 13.71 V
Address 47: Sound System
Cannot be reached
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0025
Serial number: 05071404080424 Dataset Number: 5G0157v____ 0055
Coding: 003F0020DE01048000801000
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 3FDAB80ED7F6ABC2361-806A
Rear Passenger Door Control Module:
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_PSG 005 0005
Serial number: 00000000000003289402
Coding: 050000
2 Faults Found:
458752 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 117
Mileage: 103166 km
Date: 2023.04.17
Time: 16:09:12
458857 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 117
Mileage: 103166 km
Date: 2023.04.17
Time: 16:09:12
Address 55: Headlight Range (J745) Labels:| 7P6-907-357.clb
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Revision: -------- Serial number: -------------- Dataset Number: 5G0036v____ 0021
Coding: 02AE01000B000200
ASAM Dataset: EV_HeadlRegulVWAFSMQB 001120
ROD: EV_HeadlRegulVWAFSMQB.rod
Left Headlamp Power Output Stage:
Subsystem 1 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0002
Coding: 2E0000
Right Headlamp Power Output Stage:
Subsystem 2 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0002
Coding: 2E0000
2 Faults Found:
13705987 - Databus
[ESP_19: Fehlerwert im Signal ESP_HR_Radgeschw]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 226
Mileage: 105099 km
Date: 2023.09.09
Time: 13:45:09
13705485 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 117
Mileage: 103166 km
Date: 2023.04.17
Time: 16:09:12
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-HGH2.clb
Part No SW: 5NA 035 020 D HW: 5NA 035 020
Component: MU-H-ND-EU H54 1367
Serial number: A845D0JS037917 Dataset Number: MIB_H4CK1NG 0001
Coding: 02731001FF00000071110101C0880A101F0107F601A00400DF
Shop #: WSC 12345 123 61029
ASAM Dataset: EV_MUHig4CGen2HBAS 001001
ROD: EV_MUHig4CGen2HBAS_VW37.rod
VCID: 323CE13A14A476AAC9F-8066
Display and control head 1 for information electronics:
Subsystem 1 - Part No SW: 5G6 919 606 HW: 5G6 919 606
Component: ABT_High-2 H52 9130
Serial number: VWZ6ZJW0512585
Data carrier:
Subsystem 2 - Part No SW: V03 959 806 NB HW: -----------
Component: ECE 2021 --- 0189
Serial number: --------------------
Compact disc data bank:
Subsystem 3 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2 --- 1016
7 Faults Found:
1543 - Control Module Incorrectly Coded
U1014 00 [009] - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 117
Mileage: 103166 km
Date: 2023.04.17
Time: 16:09:16
Voltage terminal 30: 12.2 V
Byte_Coding_Condition-byte_0_condition: OK
Byte_Coding_Condition-byte_1_condition: OK
Byte_Coding_Condition-byte_10_condition: ERROR
Byte_Coding_Condition-byte_11_condition: ERROR
Byte_Coding_Condition-byte_12_condition: ERROR
Byte_Coding_Condition-byte_13_condition: ERROR
Byte_Coding_Condition-byte_14_condition: ERROR
Byte_Coding_Condition-byte_15_condition: ERROR
Byte_Coding_Condition-byte_16_condition: ERROR
Byte_Coding_Condition-byte_17_condition: ERROR
Byte_Coding_Condition-byte_18_condition: ERROR
Byte_Coding_Condition-byte_19_condition: ERROR
Byte_Coding_Condition-byte_2_condition: OK
Byte_Coding_Condition-byte_20_condition: ERROR
Byte_Coding_Condition-byte_21_condition: ERROR
Byte_Coding_Condition-byte_22_condition: ERROR
Byte_Coding_Condition-byte_23_condition: ERROR
Byte_Coding_Condition-byte_24_condition: ERROR
Byte_Coding_Condition-byte_25_condition: ERROR
Byte_Coding_Condition-byte_26_condition: ERROR
Byte_Coding_Condition-byte_27_condition: ERROR
Byte_Coding_Condition-byte_3_condition: OK
Byte_Coding_Condition-byte_4_condition: OK
Byte_Coding_Condition-byte_5_condition: OK
Byte_Coding_Condition-byte_6_condition: OK
Byte_Coding_Condition-byte_7_condition: OK
Byte_Coding_Condition-byte_8_condition: OK
Byte_Coding_Condition-byte_9_condition: OK
1555 - Check Software Version Management
B201A 00 [009] - -
[Check software version management]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 30
Reset counter: 183
Mileage: 103166 km
Date: 2023.04.17
Time: 16:09:21
Voltage terminal 30: 12.1 V
Status_Software_Version_Management-module_name: MDUV624/Main
2565 - GPS Antenna
B1054 13 [009] - Open Circuit
[GPS aerial - open circuit]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 192
Mileage: 105099 km
Date: 2023.10.03
Time: 13:26:07
Voltage terminal 30: 14.5 V
6697 - Databus
[Airbag: no communication]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 117
Mileage: 103166 km
Date: 2023.04.17
Time: 16:09:14
Network diagnosis-Status: Enabled
6678 - Digital sound System control module
U106A 00 [009] - No Communication
[Control module for sound system: no communication]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 117
Mileage: 103166 km
Date: 2023.04.17
Time: 16:09:40
7178 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Park assist OPS (0x0A) - function restriction due to communication error - BapErr_retry not successful]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 224
Mileage: 105067 km
Date: 2023.08.26
Time: 17:09:19
Voltage terminal 30: 14.8 V
BAP-BAP_Function_ID: 02
7199 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Reversible belt tensioner (0x1F) - function restriction due to communication error - BapErr_retry not successful]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 117
Mileage: 103166 km
Date: 2023.04.17
Time: 16:09:17
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 5G0 907 159 B HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0006
Serial number: 140611200218
ASAM Dataset: EV_SoundActuaGen2AU64X 003010
ROD: EV_SoundActuaGen2AU64X.rod
VCID: 2D06F2460D9A295294D-8078
End----------(Elapsed Time: 01:54, VBatt
Acc
Airbag
Abs
Handbrake
Engine management
Stability
www.Ross-Tech.com
11 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 105099 km
Date: 2023.09.09
Time: 13:46:34
T_AST_SAE: 0 s
MAP_MES_SAE: 48 kPa
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 105099 km
Date: 2023.09.09
Time: 12:40:54
STATE_LS_SAE[1]: CL
T_AST_SAE: 3660 s
MAP_MES_SAE: 46 kPa
U0416 00 [032] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 105099 km
Date: 2023.09.09
Time: 13:49:56
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 105099 km
Date: 2023.09.09
Time: 13:50:56
STATE_LS_SAE[1]: CL
T_AST_SAE: 59 s
MAP_MES_SAE: 53 kPa
P06E9 00 [032] - -
U0151 00 [047] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Mileage: 103166 km
Date: 2023.04.17
Time: 16:09:15
ECU_STATE: ENG_STOP
T_ES: 6 min
U0159 00 [032] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Mileage: 105067 km
Date: 2023.08.26
Time: 17:08:55
T_ES: 0 min
U0415 00 [032] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 105099 km
Date: 2023.09.09
Time: 13:45:09
T_ES: 0 min
U0415 00 [032] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 105099 km
Date: 2023.09.09
Time: 13:45:09
T_ES: 0 min
Coding: 0014
1 Fault Found:
8 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 231
Mileage: 103536 km
Date: 2023.05.06
Time: 20:32:24
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 157
Mileage: 103166 km
Date: 2023.04.17
Time: 00:00:23
8200 - Databus
Freeze Frame:
Fault Priority: 6
Reset counter: 192
Mileage: 103166 km
Date: 2023.04.17
Time: 00:00:23
8204 - Databus
Freeze Frame:
Fault Priority: 6
Reset counter: 192
Mileage: 103166 km
Date: 2023.04.17
Time: 00:00:23
8206 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 95
Reset counter: 192
Mileage: 103166 km
Date: 2023.04.17
Time: 00:00:23
Freeze Frame:
Fault Priority: 6
Fault Frequency: 6
Reset counter: 226
Mileage: 103166 km
Date: 2023.04.17
Time: 00:00:33
32869 - Databus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 117
Date: 2023.03.26
Time: 17:28:10
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 230
Mileage: 103536 km
Date: 2023.05.06
Time: 20:32:24
Revision: 00001K08
Air quality sensor:
1 Fault Found:
459009 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 117
Mileage: 103166 km
Date: 2023.04.17
Time: 16:09:12
Coding: 0E4DDD
Coding: 00A8DD
Alarm horn:
3 Faults Found:
528405 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 117
Mileage: 103166 km
Date: 2023.04.17
Time: 16:09:12
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 12.0 V
558101 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 117
Mileage: 103166 km
Date: 2023.04.17
Time: 16:09:12
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 12.0 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 215
Mileage: 105061 km
Date: 2023.07.30
Time: 14:29:22
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 13.1 V
Coding: 0071051011
1 Fault Found:
13637426 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 226
Mileage: 105099 km
Date: 2023.09.09
Time: 13:45:09
9 Faults Found:
C10DF 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 226
Mileage: 105099 km
Date: 2023.09.09
Time: 13:45:09
1058 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 226
Mileage: 105099 km
Date: 2023.09.09
Time: 13:45:09
1059 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 226
Mileage: 105099 km
Date: 2023.09.09
Time: 13:45:09
0283 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 117
Mileage: 103166 km
Date: 2023.04.17
Time: 16:09:12
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 186
Mileage: 103166 km
Date: 2023.04.17
Time: 16:09:12
1083 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 226
Mileage: 105099 km
Date: 2023.09.09
Time: 13:45:09
1118 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 226
Mileage: 105099 km
Date: 2023.09.09
Time: 13:45:09
1081 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 226
Mileage: 105099 km
Date: 2023.09.09
Time: 13:45:09
1042 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 226
Mileage: 105099 km
Date: 2023.09.09
Time: 13:45:09
Address 15: Airbags
Cannot be reached
Coding: 0C10
1 Fault Found:
16776962 - Databus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 117
Mileage: 103166 km
Date: 2023.04.17
Time: 16:09:12
Generator:
Coding: 2DFFFF
4 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 227
Mileage: 105067 km
Date: 2023.08.26
Time: 17:09:01
Terminal 15: On
U0151 00 [009] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 117
Mileage: 103166 km
Date: 2023.04.17
Time: 16:09:13
Terminal 15: On
B130E 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 8
Reset counter: 200
Mileage: 103304 km
Date: 2023.05.06
Time: 10:04:03
Terminal 15: On
P30DE 00 [008] - -
Freeze Frame:
Fault Priority: 5
Reset counter: 226
Mileage: 103229 km
Date: 2023.04.30
Time: 21:29:41
Terminal 15: On
Coding: 0001
1 Fault Found:
16656 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 226
Mileage: 105099 km
Date: 2023.09.09
Time: 13:45:09
Coding: 1D0000
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 117
Mileage: 103166 km
Date: 2023.04.17
Time: 16:09:12
458752 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 117
Mileage: 103166 km
Date: 2023.04.17
Time: 16:09:12
458857 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 117
Mileage: 103166 km
Date: 2023.04.17
Time: 16:09:12
Coding: 8103
2 Faults Found:
19716 - Databus
Freeze Frame:
Fault Priority: 6
Reset counter: 226
Mileage: 103536 km
Date: 2023.05.06
Time: 20:32:24
Motor status: 02
KFC: 4D
KFA: 00 04
20228 - Databus
Freeze Frame:
Fault Priority: 6
Reset counter: 226
Mileage: 105099 km
Date: 2023.09.09
Time: 13:45:10
Motor status: 01
KFC: 4F
KFA: 00 04
Cannot be reached
Coding: 050000
2 Faults Found:
458752 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 117
Mileage: 103166 km
Date: 2023.04.17
Time: 16:09:12
458857 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 117
Mileage: 103166 km
Date: 2023.04.17
Time: 16:09:12
Coding: 2E0000
Coding: 2E0000
2 Faults Found:
13705987 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 226
Mileage: 105099 km
Date: 2023.09.09
Time: 13:45:09
13705485 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 117
Mileage: 103166 km
Date: 2023.04.17
Time: 16:09:12
Data carrier:
7 Faults Found:
U1014 00 [009] - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 117
Mileage: 103166 km
Date: 2023.04.17
Time: 16:09:16
B201A 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 30
Reset counter: 183
Mileage: 103166 km
Date: 2023.04.17
Time: 16:09:21
2565 - GPS Antenna
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 192
Mileage: 105099 km
Date: 2023.10.03
Time: 13:26:07
6697 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 117
Mileage: 103166 km
Date: 2023.04.17
Time: 16:09:14
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 117
Mileage: 103166 km
Date: 2023.04.17
Time: 16:09:40
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 224
Mileage: 105067 km
Date: 2023.08.26
Time: 17:09:19
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 117
Mileage: 103166 km
Date: 2023.04.17
Time: 16:09:17
