motoracer47
- Texas
- MK7 Alltrack
2017 VW Golf Alltrack SEL
Hi,
Just wanted to see if anyone had any ideas on what I got going on. I replaced my distance sensor with a used unit. I of course originally had codes for CP being active, then after CP was removed I had codes for no enable identification, which I discovered meant I needed FeC/swap coding. Both of those have been taking care of and I no longer have any codes for them, but ACC, front assist, and regular cruise control still does not work, and I have codes for missing databus messages in both the sensor and ECM. The car does have lane keeep assistance, and it works fine. I have verified my wiring as best I can and it seems ok. Not sure what to do at this point....any ideas?
(PS..I removed the sensor and have a calibration fault, but originally that fault was not there and I still had the databus errors as well as no workie)
Here are the scans.
First scan was after CP removal but before FeC
Second scan is how it sits now.
Hi,
Here are the scans.
Code:
Wednesday,23,August,2023,09:07:56:14879
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 23.3.1.0 (x64)
Data version: 20230421 DS346.2
www.Ross-Tech.com
VIN: 3VWH17AU6HM506089 License Plate:
Mileage: 79038km-49111mi Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 2B 42 44 47 52 55 5F
75 A5
VIN: 3VWH17AU6HM506089 Mileage: 79038km-49111miles
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
75-Telematics -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
Address 01: Engine (J623-CXBB) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 264 L HW: 06K 907 425 B
Component: 1.8l R4 TFSI H13 0002
Revision: --H13--- CVN: F8DEB251
Coding: 311D00322466002F1000
Shop #: WSC 00066 790 00149
ASAM Dataset: EV_ECM18TFS0208V0906264L 001003
ROD: EV_ECM18TFS0208V0906264K.rod
VCID: 45817070C49BF9BBB8-8010
VINID: 0E69D804746519874500600824B36E12F5
1 Fault Found:
22008 - No Communications with Cruise Control (Front) Distance Sensor
U0235 00 [047] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Mileage: 79020 km
Date: 2023.08.21
Time: 07:45:50
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 77 C
Intake air temperature: 51 C
Ambient air pressure: 990 mbar
Voltage terminal 30: 12.324 V
Unlearning counter according OBD: 40
Engine: operating status: ES
ECU_STATE: ENG_STOP
Engine oil temperature: 52.0 C
Time since engine start: 0.0 s
T_ES: 17 min
Cruise control switch actuation-Main switch: Not operated
Cruise control switch actuation-Set: Not operated
Cruise control switch actuation-Resume: Not operated
Cruise control switch actuation-Status: OK
Cruise control switch actuation-Accelerate: Not operated
Cruise control switch actuation-DELAY: Not operated
Cruise control switch actuation-Cancel: Not operated
Cruise control switch actuation-Main switch hardware: Not operated
Cruise control switch actuation-Coding: plausible
Cruise control switch actuation-Limit function: not selected
Cruise control switch actuation-Limit button: Not operated
Cruise control switch actuation-Main switch CAN: Not operated
Cruise control switch actuation-Large increment: Not operated
Cruise control switch actuation-Control component verified: Yes
T_AST_SAE: 0 s
Readiness: 0010 1101
Address 02: Auto Trans (J743) Labels: 0D9-927-770.clb
Part No SW: 0D9 300 012 F HW: 02E 927 770 AQ
Component: DQ250-6F MQB H54 4901
Revision: 06354004 Serial number: TFK01606170834 CVN: 000027DD
Coding: 0014
ASAM Dataset: EV_TCMDQ250021 001001
ROD: EV_TCMDQ250021.rod
VCID: 1939EC0018A3AD5B2C-804C
No fault code found.
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 614 517 BK HW: 5Q0 614 517 AH
Component: ESC H62 0736
Revision: 00000000 Serial number: 61796000000228
Coding: 43FA6AA1342009728077130881CC29C2562C9001C881943C16435052E02903
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_Brake1UDSContiMK100IPB 035019
ROD: EV_Brake1UDSContiMK100IPB_035_VW37.rod
VCID: 7BF5D688F2DF7F4B9E-802E
1 Fault Found:
8192 - Databus
U1121 00 [009] - Missing Message
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 45
Date: 2023.08.21
Time: 07:45:51
Address 05: Acc/Start Auth. (J518) Labels:| 5Q0-959-435.clb
Part No SW: 5Q0 959 435 B HW: 5Q0 959 435
Component: VWKESSYMQB 021 0710
Revision: 00021000 Serial number: 0406878564 Dataset Number: V03935230D0007
Coding: 032C0C
ASAM Dataset: EV_KessyHellaMQBAB 002019
ROD: EV_KessyHellaMQBAB_002.rod
VCID: 3B751688B25FBF4BDE-806E
Address 08: Auto HVAC (J255) Labels:| 5G0-907-044.clb
Part No SW: 5GM 907 044 C HW: 5GM 907 044 C
Component: Climatronic H04 1601
Revision: 00001K03 Dataset Number: 0000
Coding: 02020024200100000105000012111402
ASAM Dataset: EV_ACClimaBHBVW37X 006142
ROD: EV_ACClimaBHBVW37X_006_VW37.rod
VCID: 44876D74CFA1C0B3AF-8010
Fresh air blower control module (front):
A/C pressure/coolant temperature sensor:
Air quality sensor:
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 087 AA HW: 5Q0 937 087 AA
Component: BCM PQ37BOSCH 028 0162
Revision: -------- Serial number: 865820071600SA Dataset Number: V03935240CJ 0001
Coding: 00511B464041A2E969E44000001407201800000000000000000000000000
Shop #: WSC 00066 790 00225
ASAM Dataset: EV_BodyContrModul1UDSBosc 015002
ROD: EV_BCMBOSCH_015.rod
VCID: 7AFBD38CFDE5464385-802E
Wiper motor control module:
Subsystem 1 - Part No SW: 5GM 955 119 HW: 5GM 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 160810 043 0581
Serial number: 160815063228
Coding: 0E4DDD
Rain/Light Recognition Sensor:
Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
Component: RLHS 042 0105
Serial number: S7Y16M07D01H03M11S53
Coding: 00A8DD
Sunroof control module:
Subsystem 3 - Part No SW: 5G0 959 591 A HW: 8V3 959 591 A
Component: J245 PS22.409 H03 0004
Serial number: 0000FST000XXIBN00000
Coding: 191800
Roof shade control module:
Subsystem 4 - Part No SW: 5G0 959 591 A HW: 8V3 959 591 A
Component: J394 PS22.409 H03 0004
Serial number: 0000FST000XXI9L00000
Coding: 191800
Humidity sensor: interior:
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Part No SW: 5Q0 919 298 K HW: 5Q0 919 298
Component: PARKHILFE PLA H12 0054
Revision: -------- Serial number: 39431616601350 Dataset Number: 5GM039v__B_ 0113
Coding: 0031163011
ASAM Dataset: EV_EPHVA2CAU3700000 003021
ROD: EV_EPHVA2CAU3700000_003.rod
VCID: 479D7A78FE97EBAB4A-8012
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V2.clb
Part No SW: 5Q0 907 572 G HW: 5Q0 907 572 G
Component: ACC BOSCH MQB H10 0571
Dataset Number: 8V1909863AB 0001
Coding: B50087C119FFC42474988055000026
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ACCBOSCHVW416 001005
ROD: EV_ACCBOSCHVW416_001_VW37.rod
4 Faults Found:
2092 - Databus
U1123 00 [009] - Received Error Message
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 45
Mileage: 79020 km
Date: 2023.08.21
Time: 07:45:50
Control Module temperature: 55 C
Voltage terminal 15: 12.2 V
Velocity_vehicle_reference: 0.00 m/s
Longitudinal_acceleration_vehicle_reference: 0.00 m/s
Status_ACC_System: ACC_reversible_error
1807 - No Enable Identifications Active
B2032 00 [009] - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 45
Mileage: 79020 km
Date: 2023.08.21
Time: 07:45:50
1054 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 45
Mileage: 79020 km
Date: 2023.08.21
Time: 07:45:50
1116 - Databus
U1122 00 [009] - Implausible Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 45
Mileage: 79020 km
Date: 2023.08.21
Time: 07:45:50
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 5Q0 959 655 J HW: 5Q0 959 655 J
Component: AirbagVW20 010 0830
Serial number: 003GCR058N3B Dataset Number: 5GM003V____ 0044
Coding: 8CCCFC00000000005000001AC24800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002144
ROD: EV_AirbaVW20SMEVW37X_VW37.rod
Seat occupied recognition passenger side:
Subsystem 1 - Part No SW: 4M0 959 339 B HW: 4M0 959 339 B
Component: BF-Gewichtss. H12 0021
Serial number: IBH000000000005IJW8%
Coding: 303137
Crash sensor for side airbag: driver side:
Subsystem 2 - Part No SW: ----------- HW: 480 002 306 16
Component: SideSensor_Df 001 0887
Serial number: 357000000004A0711C18
Coding: 2D2D2D
Front Passenger's Side Airbag Crash Sensor:
Subsystem 3 - Part No SW: ----------- HW: 480 002 306 16
Component: SideSensor_Pf 001 0887
Serial number: 35800000000999651C1P
Coding: 2D2D2D
Rear Side Airbag Crash Sensor (on driver's side):
Subsystem 4 - Part No SW: ----------- HW: 480 402 206 16
Component: SideSensor_Dr 001 6149
Serial number: 3510002C121160C2703F
Coding: 2D2D2D
Passenger side rear thorax airbag crash sensor:
Subsystem 5 - Part No SW: ----------- HW: 480 402 206 16
Component: SideSensor_Pr 001 6149
Serial number: 3520002A320F1954508V
Coding: 2D2D2D
Crash sensor for front airbag: driver side:
Subsystem 6 - Part No SW: ----------- HW: 480 401 806 16
Component: FrontSensor_D 001 6149
Serial number: 3550002C920EDB640303
Coding: 2D2D2D
Crash sensor for front airbag: front passenger side:
Subsystem 7 - Part No SW: ----------- HW: 480 401 806 16
Component: FrontSensor_P 001 6149
Serial number: 3560002BB20EDB643016
Coding: 2D2D2D
Address 16: Steering wheel (J524) Labels:| 5Q0-953-549.clb
Part No SW: 5Q0 953 521 BB HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0235
Revision: FF034034 Serial number: 20160703501041
Coding: 0C10
ASAM Dataset: EV_SMLSVALEOMQB 001015
ROD: EV_SMLSVALEOMQB.rod
VCID: 73E5FEA8DA8F370BC6-8026
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 5G1 920 840 B HW: 5G1 920 840 B
Component: KOMBI 244 8311
Coding: 0BA4101DED90CF0502886A031000000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009051
ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
VCID: 2643D7FC59DD12A391-8072
Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 AM HW: 5Q0 907 530 M
Component: GW MQB High 212 2265
Revision: -------- Serial number: 21051610801395 Dataset Number: V03935242HR 0001
Coding: 0901000830085900FB00221A1E0F00000001050000000000000000000000
Shop #: WSC 00066 790 00199
GVL: 01D43C0000000600408C90008000C80000000000000000000000000000000000
ASAM Dataset: EV_GatewConti 013020
ROD: EV_GatewConti_013.rod
VCID: 7CF7D594F7D1787397-8028
Generator:
Multifunction steering wheel control module:
Subsystem 2 - Part No SW: 5G0 959 442 R HW: 5G0 959 442 R Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H17 0040
Serial number: 29160000711570116142
Coding: 35FFFF
Inverter for electrical outlet:
Subsystem 3 - Part No SW: 5Q0 907 155 A HW: 5Q0 907 155 A
Component: WECHSELRICHTE H53 0041
Serial number: 0125984
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 H HW: 0CQ 525 130
Component: Haldex4Motion H52 7083
Serial number: HA1-00025.05.16 Dataset Number: v1260x015G0 0000
Coding: 0001
ASAM Dataset: EV_AllWheelContrHA1VW37X 004013
ROD: EV_AllWheelContrHA1VW37X_004.rod
VCID: 4A9B434CED8516C355-801E
Address 2B: Steer. Col. Lock (J764) Labels:* 5Q0-905-861.clb
Part No SW: 5Q0 905 861 A HW: 5Q0 905 861 A
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 16000103380004
Coding: 5D00000000000000
ASAM Dataset: EV_ELVMarquMQB 004111
ROD: EV_ELVMarquMQB_004_VW37.rod
VCID: 34673DB49F0170331F-8060
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 E HW: 5Q0 959 593 B
Component: TSG FS 020 0041
Serial number: 260716060501X3 Dataset Number: V03935226UJ 0009
Coding: 003A13200000020000000000
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 43856E68CAAFC78B96-8016
Rear Driver Side Door Control Module:
Subsystem 1 - Part No SW: 5Q4 959 811 D HW: 5Q4 959 811 D Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000013257383
Coding: 011000
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 5Q0 909 144 T HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 129 1072
Dataset Number: V03935242JV 0001
Coding: 9302
ASAM Dataset: EV_SteerAssisMQB 013144
ROD: EV_SteerAssisMQB_013.rod
Address 47: Sound System (J525) Labels:| 5Q0-035-456.clb
Part No SW: 5Q0 035 456 HW: 5Q0 035 456
Component: MIB2_lite_amp H20 0150
Revision: 00000001 Serial number: VWZ8Z1GBA0219S4 Dataset Number: 5GM050v____ 0212
Coding: 2200000000AAAAAA000000000000
ASAM Dataset: EV_AMPMst12C1Gen2ALPI 001003
ROD: EV_AMPMst12C1Gen2ALPI.rod
VCID: 6DD1E8D0BCABE1FB10-8038
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 E HW: 5Q0 959 592 B
Component: TSG BFS 020 0041
Serial number: 190716060507OB Dataset Number: V03935226UK 0009
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 428B6B6CD5B5CE839D-8016
Rear Passenger Door Control Module:
Subsystem 1 - Part No SW: 5Q4 959 812 D HW: 5Q4 959 812 D Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000013163912
Coding: 091000
Address 55: Headlight Range (J745) Labels:| 7P6-907-357.clb
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Revision: -------- Serial number: -------------- Dataset Number: V03935205NP 0021
Coding: 062A00010B000400
ASAM Dataset: EV_HeadlRegulVWAFSMQB 001120
ROD: EV_HeadlRegulVWAFSMQB.rod
VCID: 408F6164DBB9DC938B-8014
Left Headlamp Power Output Stage:
Subsystem 1 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0004
Coding: 2E0000
Right Headlamp Power Output Stage:
Subsystem 2 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0004
Coding: 2E0000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 3Q0 035 876 A HW: 3Q0 035 876 A
Component: MU-S-NS-US 840 0755
Serial number: Dataset Number: V03935247DB 0001
Coding: 027302020000000051220002001808009F0108F401200105C6
ASAM Dataset: EV_MUStd4CDELP 001001
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 326B3BAC65157E030D-8066
Display and control head 1 for information electronics:
Subsystem 1 - Part No SW: 5GM 919 605 HW: 5GM 919 605
Component: ABT_Std-2_Nav H53 1031
Serial number: VWZ8Z9SJX009PL
Data carrier:
Subsystem 2 - Part No SW: 3G0 919 866 AC HW: -----------
Component: NAR 2016/17 --- 0445
Serial number: --------------------
1 Fault Found:
7173 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 45
Mileage: 79020 km
Date: 2023.08.21
Time: 07:45:54
Voltage terminal 30: 12.3 V
BAP-BAP_Function_ID: 02
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 007 0568
Dataset Number: V03935236TB 0001
Coding: 02730202C2823A017F1E06020000
ASAM Dataset: EV_OCULowMQB 001006
ROD: EV_OCULowMQB.rod
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb
Part No SW: 3Q0 980 654 G HW: 3Q0 980 654
Component: MQB_B_MFK H04 0231
Serial number: 12061611P10062 Dataset Number: V03935240AT 0001
Coding: 000307020002020100221344C040490084000E100020
ASAM Dataset: EV_MFKBoschMQBB 001001
ROD: EV_MFKBoschMQBB_001_VW36.rod
End-------------------------(Elapsed Time: 05:34)--------------------------
Code:
Thursday,31,August,2023,14:28:21:14879
www.Ross-Tech.com
Mileage: 79073km-49133mi Repair Order:
75 A5
VIN: 3VWH17AU6HM506089 Mileage: 79073km-49133miles
03-ABS Brakes -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
1 Fault Found:
17176 - Databus
U1123 00 [039] - Received Error Message
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Mileage: 79073 km
Date: 2023.08.30
Time: 20:39:00
Coolant temperature: 40 C
Intake air temperature: 41 C
Voltage terminal 30: 11.894 V
Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
Drivetrain coordinator: brake fault status-Deceleration sensor not available: No
Drivetrain coordinator: brake fault status-Deceleration sensor malfunction: No
Drivetrain coordinator: brake fault status-ESP system error: No
Drivetrain coordinator: brake fault status-ESP system malfunction due to inaccurate engine torque: No
Drivetrain coordinator: brake fault status-ESP indicates TSK message consistency error: No
Drivetrain coordinator: brake fault status-TSK/ESP handshake error: No
Drivetrain coordinator: brake fault status-ESP automatic engagement malfunction: No
Drivetrain coordinator: brake fault status-Brake light implausible: No
Readiness: 1010 0101
Coding: 0014
Coding: 032C0C
Air quality sensor:
Coding: 0E4DDD
Coding: 00A8DD
Coding: 191800
Coding: 191800
Coding: 0031163011
4 Faults Found:
0267 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
C1103 00 [009] - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 47
Mileage: 79073 km
Date: 2023.08.30
Time: 20:38:24
Control Module temperature: 48 C
Voltage terminal 15: 11.8 V
Status_ACC_System: ACC_irreversible error
0791 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
C1103 00 [009] - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 47
Mileage: 79073 km
Date: 2023.08.30
Time: 20:38:24
2092 - Databus
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 47
Mileage: 79073 km
Date: 2023.08.30
Time: 20:38:24
1054 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 47
Mileage: 79073 km
Date: 2023.08.30
Time: 20:38:24
Coding: 303137
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 0C10
Generator:
Coding: 35FFFF
Coding: 0001
Coding: 011000
Coding: 9302
Coding: 091000
Coding: 2E0000
Coding: 2E0000
Data carrier:
End-------------------------(Elapsed Time: 05:37)--------------------------
