ACC High - 210km/h retrofit on Golf MK7
KyACRASH
Fort Walton Beach, FL
2015 GTI 6MT, 04 R32
if anyone is interested in starting this retrofit, I have some spare parts available for sale, will give a deal for a forum member. only other parts you'll need are the crash bar/bracket and wire harness.
rear ABS sensors (pair) WHT003864A
multifunction steering wheel buttons (for golf, not GTI) 5G0959442R
round MRR radar 5Q0907541G
Setam
Hi Guys :)
First of all, great job Piotr ! I've read your blog and wanted to congratulate you on these great retrofit guides. I'm sure it helped a lot of people, including me.
I plan to start this retrofit soon enough but I have two questions:
1. During research, I've found a LRR radar from an Audi A6 C7 radar at a reasonable price (PN: 4G0907541B) and was wondering if this radar could work for this project with proper calibration, of course. I will attach a photo of the back of the radar.
2. I'm not sure if my ABS pump is compatible with this project. I have a VCDS scan but not sure where to look:
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 907 379 AC HW: 5Q0 907 379 D
Component: ESC H75 0437
Revision: 00000000 Serial number:
Coding: 01FA62A120230A740379060201CB2580460450C06080A4F300480024C0
Shop #: WSC 00028 028 00025
ASAM Dataset: EV_Brake1UDSContiMK100IPB 008020
ROD: EV_Brake1UDSContiMK100IPB_VW37.rod
VCID: 7DF19392EC3044AACB-8028
davide.bonetti
ITALY
1) forget it, A6 is not MQB platform. You need to get 5Q0 907 541 x.
2) only way to make sure is go to a dealer with the part number and check on ETKA which PR codes are supported by that ABS.
8T7 needs to be supported if the car is manual shifting OR
8T8 needs to be supported if the car is automatic shifting.
Luka64
Croatia
Golf MK7 GTD
Hello guys,
I need your help! I have Golf MK7 GTD. The car has a factory built-in Front Assist as well as a Lane Assist.
In the front bumper, below the table, there is a factory-fitted radar for Front Assist.
Car parts:
Radar model: 5Q0 907 572 A
Steering wheel keyboard model (before): 5G0 959 442 M, replaced with: 5G0 959 442 N (after)
ABS module: 5Q0 907 379 AA
Can you please tell me if the radar sensor and the ABS module are compatible with the ACC?
Thanks!
o_a_ravi
Hello guys,
Car parts:
Thanks!
Do you have electronic parking brakes ? your ABS Module - ...AA should support ACC without issue, however i am not sure on the radar model. May need a SWaP / FEC codes at a minimum to unlock the ACC features.
Luka64
Croatia
Golf MK7 GTD
I do have electronic parking brakes.
Thanks for the info on ABS module.
I heard from one other source that my model of the radar is not compatible for ACC, that I should get 5Q0 907 572 G instead of my 5Q0 907 572 A.
I find that hard to believe, since the diference is only im the final leter A - G
And also, there is an original sticker on the back side of my radar that has word ACC printer on it. It literaly says ACC on the radar.
That is why I wanted to make sure with you guys.
doctor
VAG
Your part list probably ;
3Q0907379AA will change for support new gen acc.
3QF907561, A, Or D change more features and Improvements
WHT003864A/B rear sensors
And steering wh buttons.
fckw70
Poland
Golf 1.4 DSG
Hello :)
I am owner of Golf 7 with normal cruise control (not active). I am going to retrofit ACC to my prelift version and have few technical questions.
1. I want to mount the pACC the highest version with Trafic Jam Asisst Front Assist. I know it works with lift parts
camera: 3q0 980 654
radar: 3QF 907 561 MRRevo14F
Can the radar be mounted under number plate in the same place like prelift used to have? Is the shape of radar the same and will it fit to 5q0 907 461A mount ?
2. If it's physiccaly possible to mount it, will the electronic work correctly when they are in other place than from manufacture ? On audi A3 8V FL it is still under number plate.
2. If index on the end on number of camera must be the same as radar to be compatible ? i have read the only difference is software, but im not sure if its neccessary to care about the letters on the end of part number.
Is there anyone who retrofitted preACC to mk7 ?
Thanks in advance for answears
doctor
VAG
Hello :)
camera: 3q0 980 654
Hey, first thing your car must be support it; mib and abs. Then we can talk about the others.
