jay745
What Would Glenn Danzig Do
- Slightly Outside Chicago
- Mk6 racecar, Tacoma
Ok
Last offer.
31k for my 18 R with 27k miles On it. Only need a front crash bar that is made of unobtainium.
no low ballers, I know what I have. Lmao!!!!!
did he offer you a GTI?
Looks right to me. @toothofwar's thread looking for the crashbar says "with autobrake" but it doesn't need to be described that way for a 7.5.
The facelift cars have the autobrake/ACC sensor behind the emblem. Prefacelift had it mounted in the lower grill so the crash bar had posts sticking out the bottom to mount the sensor.
If your car has the sensor behind the emblem you can get both types of crash bar. If you get a prefacelift "with autobrake" crash bar you could cut off the lower mount points, if you care about them being there.
I shouldn't have said "mounted in the lower grill." I should have said located in the lower grill, but mounted to the crash bar, hanging down. They are not removable.
If you have a facelift car you can buy either bar, you just won't use the mounts on the bottom since your sensor is mounted behind the emblem.
If you have a pre-facelift car with autobrake/ACC then you have to get the pre-facelift crash bar with the tabs on the bottom to mount your sensor.
That one has non auto breaking. I'll need the one with auto breaking. Ill have to dig back up the part number. All the ones I have found is the wrong part number so far.
