gixxerfool
- New Jersey
- 2016 Golf R
How hard is to pull the crash bar off the car and put it in a drill press?
Not worth the effortHow hard is to pull the crash bar off the car and put it in a drill press?
Why not? Is it more time consuming then using a hand drill for 90 minutes?Not worth the effort
If we had the right drill bits at the start would have been done in half the timeWhy not? Is it more time consuming then using a hand drill for 90 minutes?
That would be the tool for the job, we didn't have one. We considered using the impact but we decided the likelihood of breaking the bit was high.Did you guys use a corded hammer drill? Battery powered drills aren't cut out for that.
hammer drill for metal? That will dull the bit within the first 10 impacts. Metal bits are design to shave the steel, not cut it in chunks. If your not getting spirals while drilling, either your going to fast, or pushing too hard.Did you guys use a corded hammer drill? Battery powered drills aren't cut out for that.
Good to know - thanks.hammer drill for metal? That will dull the bit within the first 10 impacts. Metal bits are design to shave the steel, not cut it in chunks. If your not getting spirals while drilling, either your going to fast, or pushing too hard.
Any drill with a decent HSS bit would eat through that bar in less than a minute. I used to install the doors on the link below. We had to drill overhead two parallel holes either 3/8" or 1/2" every 24" or 36" through 1/2" thick structural steel I beams. Took around 1-2 min per hole unassisted, and 30 sec with a custom lever system that the company created.
https://www.modernfold.com/en-US/products/operable-partitions
There is no way a 1/8" crash bar is going to take that long... unless the bit is dull or the drill has no power. The awkward position will definitely make it hard... but still.
I guess I'll find out when I get to install my FMIC
If the bit is not designed to drill metal it will not work without extra effort.hammer drill for metal? That will dull the bit within the first 10 impacts. Metal bits are design to shave the steel, not cut it in chunks. If your not getting spirals while drilling, either your going to fast, or pushing too hard.
Jerry is the man.Better drill bits would definitely help. I mean, this is the starting set:
An $8 set of drill bits. Not sure about the ones my neighbor Jerry brought over, but they were definitely better than my $8 ones...
