Agray
- Washington
EQT stage 2 ECU & DSG Tune
Had something really weird happen with the DSG this morning... I was coming to a stop sign that I rolled through while making a right turn at probably 5MPH.
As I was making the turn at low speed, I lightly pressed the throttle and the DSG wasn't engaged at all and it actually free revved a bit.
I didnt look at the tac, but couldn't have been more than a couple hundred RPM.
When it happened, I instinctively let off the throttle and then as the RPM went down it engaged a gear and everything was fine after that.
What happened here? When I first flashed the DSG, I did the basic setting found in the EQT FAQ. The fluid has about 20k miles on it.
