I run 30 PSI for extra grip
Yeah for track and drag use and launch control and cornering it works great, rides nicer too. Blew the motor in my APR Stage 2+ 2018 DSG Golf R yesterday so now I'm going to have my motor fully built, put in a big turbo, and go full send mode for next year.9 psi below recommended pressure?
I run 39-40 PSI cold on my Golf-R which I too thought was high in the beginning.
Sent from my SM-G975U using Tapatalk
I'd like to know more details about how and what failed . What oil were you using? And how long did you go between oil changes?
Yeah it does seem high. I actually had mine around 32psi for a long time until I realized they were that low. Apparently the dealer set them at that pressure and reset the TPMS to match so I didn't know they were that low.Is anyone putting 39 pounds of air into their tires as is stated on the door jamb as a minimum?
Seems kind of high to me
Found it.Big thread on his failure on Vortex. He was pushing the motor for quite a while and understood the risk.
Found it.
Here's the thread for anyone interested in seeing what happened...
https://forums.vwvortex.com/showthread.php?9336503-2018-MK7-5-DSG-Golf-R-Blown-motor
