sean.mason.75873
Banned
Are the pressures square or are you running a split?Rear camber is -2.0, and about 28-29 psi.
Sent from my SM-G970U using Tapatalk
Right now I start at 32 f 31 r. I maintain that pressure differential and those pressures every run.
Pressure differential is a great uning tool for autocross. Just setting a starting pressure and letting pressures increase or decrease on their own just doesn't work with how sensitive cars are to tire pressure.
Was that video your fast run when the car felt loose? From the video, it didn't look loose at all.
From 26 to 32 they are very pressure agnostic, but using a pressure differential still changes the slip angle, i.e. the amount the tire deflects before gripping, as does toe. So by adjusting toe while giving pressures free reign, you're working against yourself.RE71Rs are fairly pressure agnostic, but I have not had much time with the car in its current setup, so I didn’t have time to test tire pressures. I was more concerned with balance and camber/toe settings.
The video is actually run 2, because the sun washed out the video for run 1.
I'd love to fiddle with an R and prep for DS or STU. (I think STU is where mk7 R lives for ST classes)You guys are getting me all worked up! I used to autocross in the '90's basically ending in 2000. Used to run a '91 Integra and '97 ITR, made it to 2nd place SCCA GS with the ITR in CENDiV...doesn't exist anymore. Then I moved on to lapping events, and the such until I had a child, then stopped. But I digress, for autocross I used to run higher tire pressures in the rear for better rotation...I never understood lower pressures in the back, it would never be a smooth transition from understeer to oversteer as the car rotated; first you have turn-in, then the sidewall flex, which by now you have a slip angle spike, lose grip and snap oversteer...but you can capture it back a little easier with lower pressure rear tires.
With high pressures you have turn-in, grip, progressive loss of grip. I found it much easier to pivot on low speed turns and control on long sweepers. But I ran in stock class and there wasn't much we could do. Anyway, have fun out there! Maybe some day I'll take my R out...
Where are you located now? I'm down in north Florida.
