kevinkar
- United States
Preparing to take my car in to a body shop this week for the rear end collision it sustained last week and I washed it and checked the tire pressures (also due to the freaking potholes I hit in the SF Bay Area to check and make sure all the tires were ok) and I noticed ALL 4 tires were 5-7 lbs low and the low pressure indicator has not come on for any of them. So either 7 lbs is not enough to rate as "significantly underinflated" or it's not a very good system.
In my opinion, 7 lbs is significant. My Corvette, which had internally mounted TPMS sensors, would always let me know when any of the tires were no more than 5 lbs low. While the VW system is not based on actual pressure, I would have hoped that it was sensitive enough to know when any of the tires were 5 lbs out or at least 7 lbs like two of them were. 32 psi is definitely not 39psi.
Granted the manual says it's no substitute for the owner checking and maintaining the tire pressure but what's the point of having a TPMS if it's not going to alert you when the tires are almost 20% low? So either my system is not working right or the system IS working right but not as effective as I'd like. All the tires have even wear so there is no indication of under inflation yet so maybe it's not that big a deal but I'd prefer it alert me at 5 lbs if not at least 7 lbs.
I might consider trying out a cheap bluetooth system (valve stem caps that connect to your phone) as a test to see if they alert me better than the VW system does. As it stands now, the VW system is not very good in my opinion.
