2015 MK7 Golf R - Intermittent "Error: Service Vehicle. Only leave vehicle in P position!" & "Fault: Windshield wipers"
ilikevenice
Florida
2015 Golf R
I've been experiencing a very weird issue in the past 6 months or so.
When I hit a bump on the road, or sometimes without any apparent reason, my car shows the dreaded "Error: Service Vehicle. Only leave vehicle in P position!", followed by "Fault: Windshield wipers".
At that point, I can still drive, but the wipers and the turn signals no longer work.
Usually, I pull over, turn the vehicle off, wait a few seconds and restart... sometimes it clears on the next start, some other times it takes a while to go back to normal.
I've already installed the Gear Shifter Microswitch Module (which, in most cases, fixes the "Error: Service Vehicle. Only leave vehicle in P position" problem), but the issue persists.
I ran "auto-scan" on VCDS and it reported the issues shown below, whose date/time matches the last occurrence of the issue.
Any suggestions?
Thank you all.
FROM VCDS:
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 085 AC HW: 5Q0 937 085 AC
Component: BCM MQBAB HNA H18 0137
Serial number: 01011501200269 Dataset Number: 5G0063v____ 0001
Coding: 00011A46C041A2E169E44000091C07201800000000000000000000000000
Shop #: WSC 01357 011 00200
ASAM Dataset: EV_BCMCONTI 013000
ROD: EV_BCMBOSCH_013.rod
VCID: 7AADE2EA5C54141A617-802E
544533 - Databus
U1121 00 [00001000] - Missing Message
[SMLS_01 Datenbus fehlende Botschaft]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 235
Mileage: 156822 km
Date: 2024.04.16
Time: 17:13:11
Terminal 15 status: On
Terminal 50 status: OFF
CAN-Bus_aktiv: On
Status Bremslichtschalter (HW): OFF
Status Bremslichtschalter (CAN): OFF
OFF: Not operated
Position lamps: Not operated
Automatic high beam assist: operated
Low beam: Not operated
Parking light left: Not operated
Parking light right: Not operated
last_wakeup: g¸ltiges Funktelegramm
Voltage: 13.6 V
Outside temperature: 25.5 ∞C
Address 16: Steering wheel (J527) Labels:| 5Q0-953-549.clb
Part No SW: 5Q0 953 549 C HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 14021504721552
Coding: 0410
Shop #: WSC 52073 001 1048576
ASAM Dataset: EV_SMLSKLOMQB 017001
ROD: EV_SMLSKLOMQB_017.rod
VCID: 3C2124F216E0EA2A33B-8068
2 Faults Found:
131140 - Databus
U1121 00 [00011000] - Missing Message
[Time-Out Klemmen_Status_01: Time-Out Gateway]
Intermittent - Confirmed - Not Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 235
Mileage: 156822 km
Date: 2024.04.16
Time: 17:13:10
Operating time: 258279 min
Terminal 30 power supply: 13.9 V
Vehicle speed: 5 km/h
Voltage at switch: 4.98 V
Terminal 15 status: active
System status: 30
135182 - Comfort System CAN Bus (SAE Medium Speed Bus)
U0010 00 [00011000] - Malfunction
[K-CAN im Bus-Off Zustand]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 235
Mileage: 156822 km
Date: 2024.04.16
Time: 17:13:10
Operating time: 258280 min
Terminal 30 power supply: 14.0 V
System status: 30
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 5G1 920 858 HW: 5G1 920 858
Component: KOMBI 304 4310
Coding: 0BAD081A3B80CF0502086A001400000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009043
ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
VCID: 6D87D9B61D1AB3A2F45-8038
1 Fault Found:
16776975 - Databus
[SMLS_01 keine Kommunikation]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 235
Mileage: 156822 km
Date: 2024.04.16
Time: 17:13:12
Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 AC HW: 5Q0 907 530 F
Component: GW MQB High 128 1204
Revision: -------- Serial number: 0002962109 Dataset Number: 5G0067v____ 2011
Coding: 0101000820085900EF00022A9C0F00000001050000000000000000000000
GVL: 01D43C1000000600400C10008000CC0000000000000000000000000000000000
ASAM Dataset: EV_GatewLear 011020
ROD: EV_GatewLear_011.rod
VCID: 72BDCACA04246C5A297-8026
Generator:
Multifunction steering wheel control module:
Subsystem 2 - Part No SW: 5G0 959 442 Q HW: 5G0 959 442 Q Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H10 0101
Serial number: 29150000706690035151
Coding: 300000
1 Fault Found:
131596 - Steering Column Control Module
U0212 00 [00001000] - No Communications
[Timeout Knoten 0x0C / 16 - Steuerger‰t f¸r Lenks‰ulenelektronik]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 235
Mileage: 156822 km
Date: 2024.04.16
Time: 17:13:12
Terminal 30 power supply: 13.7 V
Terminal 15: On
Address 2B: Steer. Col. Lock (J764) Labels:* 5Q0-905-861.clb
Part No SW: 5Q0 905 861 A HW: 5Q0 905 861 A
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 14000221399001
Coding: 5D00000000000000
ASAM Dataset: EV_ELVMarquMQB 004111
ROD: EV_ELVMarquMQB_004_VW37.rod
VCID: 34310CD23EB0226AFBB-8060
2 Faults Found:
12666373 - Databus
[Timeout Message SMLS_01]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 235
Mileage: 156822 km
Date: 2024.04.16
Time: 17:13:11
ELV State: 04
Information Clamps: 77 60
CoCo State: E0 01
WFS State: 1F 06
Vehicle speed: 7.73 km/h
Voltage: 76
AD-Value H-bridge: 3A
Clamp15 flip flop: SSTx: button contacts: 06
CAN signals: 00
Address 55: Headlight Range (J745) Labels:| 7P6-907-357.clb
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Revision: -------- Serial number: -------------- Dataset Number: 5G0036v____ 0021
Coding: 022202010B000400
ASAM Dataset: EV_HeadlRegulVWAFSMQB 001120
ROD: EV_HeadlRegulVWAFSMQB.rod
VCID: 40D950027A088ECA6F3-8014
Left Headlamp Power Output Stage:
Subsystem 1 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0002
Coding: 2E0000
Right Headlamp Power Output Stage:
Subsystem 2 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0002
Coding: 2E0000
1 Fault Found:
13705483 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 235
Mileage: 156822 km
Date: 2024.04.16
Time: 17:13:11
The Fed
Old Guys Rule
Florida
Any suggestions?
Thank you all.
FROM VCDS:
544533 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 235
Mileage: 156822 km
Date: 2024.04.16
Time: 17:13:11
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 13.6 V
Coding: 0410
2 Faults Found:
131140 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 235
Mileage: 156822 km
Date: 2024.04.16
Time: 17:13:10
System status: 30
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 235
Mileage: 156822 km
Date: 2024.04.16
Time: 17:13:10
System status: 30
1 Fault Found:
16776975 - Databus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 235
Mileage: 156822 km
Date: 2024.04.16
Time: 17:13:12
Generator:
Coding: 300000
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 235
Mileage: 156822 km
Date: 2024.04.16
Time: 17:13:12
Terminal 15: On
2 Faults Found:
12666373 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 235
Mileage: 156822 km
Date: 2024.04.16
Time: 17:13:11
ELV State: 04
CoCo State: E0 01
WFS State: 1F 06
Voltage: 76
CAN signals: 00
Coding: 2E0000
Coding: 2E0000
1 Fault Found:
13705483 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 235
Mileage: 156822 km
Date: 2024.04.16
Time: 17:13:11
Perhaps the steering wheel module or wiring problem. Aside from the wipers and turns, anything else not working? Both of them are on stalks.
ilikevenice
Florida
2015 Golf R
Everything else seems to be operational, though I have not checked the headlights.
The messages don't bother me, but not being able to use the turn signal is big problem while driving.
