liljonny16
- MS, FL
Is anyone running 17's with a Stoptech 355mm BBK?
Nice! Thanks for that! Now I should add, anyone running more economically priced 17's? Lol
I'd like to keep it below $1200 for wheels. I have a set of the Kosei K5R's and they don't fit. I printed out the Stoptech template and did the test fit and it "cleared." But when I was test fitting the actual wheels and brakes, no go.
Hypergram has a "sunk" face, not a good design if brake clearance is a priority. I'd have to measure, but it's close even with just PP brakes. I think Konig has other wheels (Rennform?) that would have more clearance.
Did you find anything? Ray's wheels are nice and all, but $$. Maybe really light 18s and call it a day?
What TT-RS kit did you get? I've got the Vagbremtechnic one (4 pot with 362mm rotors), but they don't have a drawing /template and I'm struggling to find 18s to fit over them - the hypergrams would need a 23mm spacer apparently! (unfortunately in NZ you can't run spacers )Konig has excellent customer service, if you email them the brake template they will do a drawing for you and get an idea of what will fit. They helped me tremendously with spec'ing out wheels for the TT-RS brake kit.
devils advocate, how would they know you're running spacers?What TT-RS kit did you get? I've got the Vagbremtechnic one (4 pot with 362mm rotors), but they don't have a drawing /template and I'm struggling to find 18s to fit over them - the hypergrams would need a 23mm spacer apparently! (unfortunately in NZ you can't run spacers )
We have to get a "warrant of fitness" every 6 months unfortunately so they would pick it up then.... Also if you get randomly pulled over the cops will check those things. They're quite tight with the rules heredevils advocate, how would they know you're running spacers?
