Super lame.We have to get a "warrant of fitness" every 6 months unfortunately so they would pick it up then.... Also if you get randomly pulled over the cops will check those things. They're quite tight with the rules here
Hypergram has a "sunk" face, not a good design if brake clearance is a priority. I'd have to measure, but it's close even with just PP brakes. I think Konig has other wheels (Rennform?) that would have more clearance.
Another problem with NZ - very difficult to get Apex wheels here (one problem after another right??)Apex should do it.
Also can't get either of those brands....If you can't get Apex (which would almost certainly clear in 18x9) then Neuspeed is probably the second best choice. The RSe10 and RSe11r has a ton of brake clearance.
I would think any of the Titan options (TR7 or TR10 in 18x8.5et43) will fit, as should the Wedsport TC-105x in the same size.
