Really three options
1. Combination of bars and springs
2. Mostly springs
3. Mostly bars
Here is what that would look like on my car.
Front | Opt 1 | Opt 2 | Opt 3 |
Spring rate in/lb | 400 | 850 | 250 |
Spring WR | 249 | 530 | 156 |
Spring WR (body roll) | 499 | 1061 | 312 |
Swaybar rate | 312 Hotchkis on soft | 160 OEM | 360 Hotchkis on hard |
Swaybar WR | 295 | 151 | 340 |
Spring WR (body roll) | 590 | 303 | 681 |
Rear | | |
Spring rate in/lb | 650 | 1200 | 575 |
Spring WR | 203 | 376 | 180 |
Spring WR (body roll) | 407 | 752 | 360 |
Swaybar rate | 842 O34 on soft | 333 OEM | 912 O34 on hard |
Swaybar WR | 139 | 55 | 151 |
Spring WR (body roll) | 279 | 110 | 302 |
Front WR/Side | 840 | 833 | 837 |
Rear WR/Side | 482 | 486 | 482 |
Roll couple % front | 0.635 | 0.631 | 0.635 |
1. Combination of bars and springs (This is my daily setup for autocross)
2. Mostly springs (If I go back to OEM front and rear bars, I have to dramatically increase spring rates to keep the same wheel rate (WR) and keep the same roll couple %)
3. Mostly bars (If I max my current front and rear bar, then I can go down on spring rates to keep the same WR and roll couple %)
#1 is a good balance between relative comfort with the selected spring rates and body roll control,
#2 is tough to live with on the street and my shocks can't dampen the body with such large energy stored in the springs, but provides the most "independent" suspension
#3 is generally more comfortable on the street, but one wheel bumps are harsher and the front may lift a tire on corner exit causing issues with power down for non-PP GTIs, the rear bar won't help much either because of the soft front springs, the rear will be off the ground all the time in corners
