Track R
- California
- R
you do realize that the Audi 8V springs regardless of OE or Sportline are shorter than the R.
Yeah. I had my car that low & with regular 245 summer tires, it was fine. When i went 265 summer / 255 200TW, had to raise up an inch at least.First pic: sloped driveway, car backed in, @$$ facing uphill.
Pics 2-3: semi flat parking lot a week or so ago.
Sharing for reference and posterity.
Trying to make sense of this data:you do realize that the Audi 8V springs regardless of OE or Sportline are shorter than the R.
Ok. You gotta try theseKW offers a 20mm front spacer which would be your only option to keep the front springs..
View attachment 303943View attachment 303944View attachment 303945
Unpacking this:KW offers a 20mm front spacer which would be your only option to keep the front springs..
1) Where did you find this info?
2) Is it showing the overall (free) length of the VW springs is ~249/250mm, and the Audi S3 is ~216-217mm?
This is news to me. Just looking to understand and confirm.
Thank you. Are these specs and data for stock VAG springs, or Eibach aftermarket springs on these applications? Asking for clarity/comprehension.Correct free length on the R springs are longer than Audi 8V S3
Unpacking this:
1) Thank you for sharing this. Had no clue it existed.
2) It does NOT exist on the ST Suspension site for North America. Just spent a bunch of time confirming. Even called them.
3) It is available in Europe, but ST won't sell it to us here in the US without confirming fitment for a specific suspension application.
In my case, Bilstein "stock style struts" with stock strut mounts may or may not work per the C/S rep. He was very black and white about it, but hey...it's a German company. They're rule followers to the letter.
4) How did you obtain your kit shown in this photo?
Link below is the only way I have found to access this kit. It does not show installed photos, and is unclear if the price is for one side or a full kit (the photos add confusion):
https://www.st-suspensions.net/shop?c_make=121&c_model=10585&c_car=59116&pgs=161&ag=stspringdistancekitfa20m
Thank you, unfortunately this won't help in my situation. I just need a taller spring in the correct linear rate to go in there.Trust me there are only one or 2 Germans working at KW North america
The spacer fits between the chassis and oe upper strut mount has nothing to do with shock mfg
It’s actually their XA coil over kit that I’m interested in, but they will not disclose spring rates. Any chance you know those?That is just a generic photo I provided you with the kit info and install instructions
The money you spent on this I would of spent it on the ST XTA kit which come with linear 70Nmm/50Nmm springs you can also chose your own rate, camber plates and rebound adj
I’m trying to keep a stock style strut mount for NVH/comfort.
Spring rubbers are a possible solution. Put them on at the track, take them off when you're done.That drop on the R springs isn't too bad, but from what I remember, the eibach springs are all close to the stock rates. I'm looking for, and probably so is Goat, essentially a stiffer stock spring, with a minimal drop.
@GoatAutomotive Did you install the magride or non-magride 034 springs? I wonder how their Golf R springs would be on a GTI.
