JD_MK7
- Boulder, CO
I just installed the reverse LED's that I got from UJ and they are awesome! Pic:
Did you just do brake LEDs or did you also find a good source for reverse LEDs as well? Just curious [emoji4]
We've tried several reverse lights. When it comes to a emitting color white in the 6000k temp range, all the kewl kids use CREE. It is likely, none of these listed as CREE are legitimate CREE(s), but it's possible.
To maximize brightness, you want to change the following adaptation settings via VCDS. You can still use any of these error free in place of you incandescent bulbs, but in general each LED will be the same brightness until you crank up the juice.
Change brightness of reverse lights:
9- Central Convenience
16-security code 31347
10-Adaptations
(6) Leuchte 28RFL LC11 dimming AB 28 - Change to 127
(6) Leuchte 29RFL RA64 dimming AB 29 - Change to 127
http://www.aliexpress.com/item/Whit...-5-CREE-XPE-R3-LED-Car-Light/32314432099.html
http://www.aliexpress.com/item/Supe...ar-Auto-Wedge-Reverse-Signal/32567915797.html
http://www.aliexpress.com/item/Erro...lbs-T15-921-168-194-For-Audi/32354535411.html
Some of my personal favs. These make great reverse, license plate and interior lights.
http://www.aliexpress.com/item/Supe...14-24SMD-Canbus-NO-ERROR-Car/32267326383.html
I'm in the market for some license plate LEDs and this price is a lot more appealing than deAutokey. Wondering if their premium is worth it/I would feel the price difference. You've been using these with no issue? And do you have any pictures?
Not sure if we have any GSW fans on here, but check out UrbanJoke V2 on a wagen!
I thought those bottom signals were only active on RoW models? Whats the story there?
So this is interesting... Ive been dealing with this and finally tonight had the time to change it. Using the OP mod, my outer tails would be stuck at 127 when the auto lights came on. They would blink in opposite phase as they should but it seemed the running lights were getting overridden. So I changed up the order of which item has priority.
Former:
Brakelite - 127
Blink dunklephase
Standlite - 35
Blink hellaphase
Current:
Former:
Standlite - 35
Brakelite - 127
Blink dunklephase
Blink hellaphase
With this setup, the rear tails now return to 35% when not being used as brake lights. They also blink accordingly when turn signal is active. Since I didnt have a third person, I will need to confirm behavior when brakes are active and turn signal is active but I'd imagine it will work as before.
Anyone with a similar issue? Sorry if this has been discussed...
FWIW I have had two deauto plate leds start flaking out. I had a spare from them and it is now also flaking out. Blinking due to two of the six leds failing. But fortunately lifetime warranty!
Were you unhappy with UrbanJoke V1 or V2?
