Awesome. Is the code boost related. Tried searching but could not find anything
Nothing else will get much more power. You're basically FBO if you've got all that. You should be over 300whp I'd think. Take another log and post it up and we can see if there is anything odd which may be robbing power.
If anyone is local with a stage 2 tunes, you should run them and see how it performs in comparison.
New logs this morning. Log 0 is 4th (hit the limiter), log 1 is 3rd:
http://www.datazap.me/u/jybyrd4606/log-1503330145?log=0&data=1-4
Any insight would be appreciated... it feels like it is running pretty fast. It's the same tank of gas I had for the dyno, though ambient was about 10f cooler.
I had these Map 6 settings when I was stock. I recently installed a CTS downpipe. Can someone help me figure out if I should stick with these or alter slightly? If so, why? (I'm still trying to understand how to read the logs..)
1500 14
2000 16
2500 18
3000 20
3500 22
4000 21
4500 20
5000 18
5500 16
6000 15
6500 15
7000 15
http://www.datazap.me/u/vstypicals/log-1503297848?log=0&data=1-4
Where are you located? your IATs are so low. I've never seen 15+ timing advance on any non stacked JB4 logs either. Crazy!
Ok everyone - take it easy on me as I'm new to the world of reading logs and worrying about tunes. Just installed my JB4 today w/ Bluetooth and took it for a shakedown run. Several good pulls all the way through 3rd. Car is stock except for a rear swaybar and RPF1/RE71Rs. So not a single thing engine wise. And I'm in Arizona where it was low 100s today, haha.
First off, I got the "431A" CEL code, which searching has shown has never been explained. Don't much care for that, but I cleared it and went on my way. Restarted car and did a 3rd gear log.
Second, the reason I'm here: link below is to the CSV log file. PLEASE help me understand what to look for and how my car is running. The trims looks good from what I gather based on the first page (which I've read). Question is, my AFR goes pretty low the higher my RPM - is that ok? In the 9s? Also, how is the timing looking? I can't figure out how to compare the numbers with the description on the first page.
I appreciate any help.
https://drive.google.com/open?id=0B-wB-MwyxaudX3FOX080Nml4cWc
Try map1. Also, what is your FOL set to?
His ambient is 60. Also, that's the top of 4th with low boost.
What should be the expected IAT compared to ambient temperature? +30 degrees? +40 degrees? +50 degrees?
