Diggs24
- de plains! de plains!
- 2015 GTI
and then realize the mpi harness already has wiring for the e sensor to the ecuOh don’t worry… in 6-8 months max you’ll be pulling that hpfp too since you’ll just go mpi
You shut upOh don’t worry… in 6-8 months max you’ll be pulling that hpfp too since you’ll just go mpi
You shut…wait…wut? loland then realize the mpi harness already has wiring for the e sensor to the ecu
Don’t worry if you stick with Cobb, that wiring and plug off the mpi harness “may” not work for their flex fuel… so you still gotta keep thiers (maybe)You shut up
now I'm looking at selling an ethanol sensor....again......for the second time, and moving over to the cobb flex fuel sensor.......so I can just have one tune from Strat (with my current 93 tune as the base). Seems I can't just have one set of:
wheels
tires
suspension
hpfp
ethanol sensors
I hear you on the wheels/tyres, my shed is full of them- My daily A4 has as set of winters mounted on MSWs in there+ 3 20"s from an A7 comp I got in a trade, my MK4 that didn't see more than 100 miles last year has a set of OEM Longbeach wheels in there, and the GTI has a set of Apex SM10s and an OEM spare sitting in there not to mention my stockpile of spare ignition coils, stock downpipes, etc. etc. lol I'd have the suspension too except I managed to sell mine and clear up some space ahahanow I'm looking at selling an ethanol sensor....again......for the second time, and moving over to the cobb flex fuel sensor.......so I can just have one tune from Strat (with my current 93 tune as the base). Seems I can't just have one set of:
wheels
tires
suspension
hpfp
ethanol sensors
the ecu has ethanol% hard-coded until the calibration is switched to use the sensor.Heard back from the tuner….. won’t read anything until I get the flex tune…. Thought I did something wrong lol
And I logically know that, but then started thinking “well maybe it should and I just jacked it up”.the ecu has ethanol% hard-coded until the calibration is switched to use the sensor.
On your 6th revision already? Should be close to finishing up your tune. How's it feel so far?well.....6th revision uploaded and ran a few logs yesterday
https://datazap.me/u/swcrow/welchv6wot2?log=0&data=6-9
yeah I try and run logs as soon as I can, so very little wait time. He's buttoning it up top end and tweaking lower end, but love it......so much power almost quicker than the IS20 and holding it up top is what I was looking for.On your 6th revision already? Should be close to finishing up your tune. How's it feel so far?
