Travis9935
- Usa
I say stalling, meaning large hesitation then grabs, technically it is because it doesn't do anything and I'm about to get rear ended! Lol Has never done this on stock or stage 1.2 file. Just this one.
Ha! Not yet, I wasn't aware until now that stage 2 is for 400whp+ Communication would be nice.have you tried going to stage 1 dsg tune and seeing if that fixes your issue?
Or go APR and take it in the rear. Your choice. LolSo it's OK for 400whp guys to get rear ended? LOL!
I was always on level street though?Have you tried messing with hill assist at all? Could be it's interacting badly with Stage 2. Try early for less hill assist, or try disabling it entirely if you want to mess with long coding.
http://forums.ross-tech.com/showthread.php?11468-MK7-golf-disable-Hill-Hold
You can still drive the car w/o an immediate adaptation. What is important is that the temp is correct. Once you perform the adaptation (at any time post tune flashing) it will reset all parameters it may have learned on your warmup drive.I wanna try something different, try and make sure the trans fluid is hot enough for adaptation. Can you run the adaptation before the tune upload? It's like 20 degrees here, by the time the tune loads it'll probably be cold again.
Hey! Just be happy with what you got!?! -EdI get a chatter at times when I let off the clutch pedal from a complete stop and some times the clutch disengages and engages before taking off from a complete stop especially when it’s cold.
Use Ed tool I had issues using obd11 and vcdsI tried the adaptation again, with dsg temp up to 68. It still wouldn't do the synchro adaptation. Everything else worked fine.
My car isn't stalling, but there is an intermittent delay when moving from a stop. Sometimes it's perfectly fine, other times, it's like it doesn't engage right when you let off the brake. After touching the gas it takes a second then engages.
This is on the latest stage 2. I might try the stage 1.x and see what it does.
Not sure if it's the adaptation of the synchros or what.
I used vcds to adapt. Might get it warmed up and try the eurodyne adaptation.
Sent from my Nexus 5X using Tapatalk
