Semi dynamic tail lights on 7.5 possible?
dman918
Algonquin IL
Hi,
Is there anything one can do to take the golf r tail lights and make the inner lights also flash on turns, preferably in a sequence with the outer ones? I know they can’t do a full dynamic signal without new tails, but wondering if there is some kind of basic mod option for the 2018 golf r. I’m thinking any kencha options, I suppose.
Thanks!
ZERO815
Köln Germany
2017 GTI SE DSG
To my knowledge the MK7.5 lights aren’t really dim able to have a good contrast between two different light modes. On your own risk you can try the following coding. You might need to adjust the 65 to a different number. The former brake/turn signal works only as a brake signal, inner and outer parking lights work as parking lights and turn signals in opposite phases. To make the turn signal more visible the parking light is disabled while the turn signals are on.
