P2263 fault code on 1.4 tsi blue motion
Crossy2425
Lancashire
Daughter has this vehicle and just recently the engine management light has been coming on. Every now and then the EPC light also comes on and the vehicle goes into limp home mode.
The only fault code showing is P2263 Turbo boost system performance.
The fault only occurs if the car is cold. When warmed up, if the engine is restarted there are no warning lights and all is fine.
I think I can discount the turbo, as I think if it was terminally faulty the car would show signs of power loss/smoke etc all the time.
So Im after some advice......what could throw this fault code up?
Thanks in advance.
2013 1.4 tsi blue motion. Petrol. 120BHP
Scotland (U.K.)
Mk7 Golf GT Estate
does it make loud owl/pigeon noise....whooooo...when you press the accelerator past 2,000rpm when cold??...
Chancers are its the servo actuator arm sticking....all VW turbo suffer this or a rattle...look in my sig for how to guide link..I did one for fixing the servo...yours is slightly different, but I can give you the specifics...
Crossy2425
Lancashire
Thanks Dave, Ive pencilled in Sunday to have a look, I’ll try that first. She did say the garage who did the MOT ‘greased’ something that was ‘sticking’.I’ll speak to them tomorrow to see what they actually did!
Crossy2425
Lancashire
Update.
Before I looked at her car, my daughter reported her car stereo kept ‘changing radio stations’ on its own.
I commented it sounds odd but unconnected with the reported fault.
Anyhow I looked at the actuator arm etc. All looks well and I couldnt really see any problem.
I cleared the code.
Despite there being no codes the car refused to rev past 3500 under no load, however when I took it on the road it pulled away perfectly. No issues and drove upto the red line.
Thinking Id fixed it, i stopped turned engine off. Turned engine on again and epc light came on. However car still drove fine, full power etc. Off and on again and light is off.
Daughter goes to work this morning and has reported the temp gauge is now erratic! It showed normal temp and has dropped to cold three times in a 4 mile journey.
Any other thoughts?
Scotland (U.K.)
Mk7 Golf GT Estate
without seeing a full VCDS scan I can't say anything except dealer visit....you have several intermittent faults which will not register fault codes in most code readers & only VCDS will reveal them...
It could be a damp connection at the engine ECU...
Crossy2425
Lancashire
Had this on VCDS now.
As can be seen there are three faults.
Low boost.
Low battery in remote
And a dirty connection on the instrument head.
Do the figures point to anything for the boost pressure?
Thursday,21,December,2017,19:44:09:27004
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 17.8.0.1 HEX-V2 CB: 0.4401.4
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: WVWZZZAUZEP024216 License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZEP024216 Mileage: 106659km-66274miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
Address 01: Engine (J623-CXSA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 016 DE HW: 04E 907 309 A
Component: 1.4l R4 TSI H08 5672
Revision: WAH08---
Coding: 01190012230411082000
Shop #: WSC 00028 028 00058
ASAM Dataset: EV_ECM14TFS01104E906016DE 002002
ROD: EV_ECM14TFS01104E906016DE_VW37.rod
VCID: 688AB18772F54C87F3A-803C
1 Fault Found:******************************
19404 - Turbo/Super Charger Boost System
P2263 00 [168] - Performance
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 39
Mileage: 105878 km
Date: 2017.11.27
Time: 14:38:27
Engine speed: 1742.50 /min
Normed load value: 9.0 %
Vehicle speed: 31 km/h
Coolant temperature: 49 °C
Intake air temperature: 22 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 14.795 V
Unlearning counter according OBD: 40
Charge pressure actuator: specified position: 140.00 %
Bypass valve f high press turboch turbine inlet: actual value: 100.29 %
Charge pressure actuator: adaptation for lower stop: 4490.6 mV
Bypass valve for high press turbocharger turbine inlet: status-Bit 0: 0
Bypass valve for high press turbocharger turbine inlet: status-Bit 16: 0
Bypass valve for high press turbocharger turbine inlet: status-Bit 24: 55
Bypass valve for high press turbocharger turbine inlet: status-Bit 8: 66
Bypass valve for high press turboch turbine inlet: uncond volt: 4503.0 mV
Charge air pressure: actual value: 1039.69 hPa
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 907 379 AA HW: 5Q0 907 379 G
Component: ESC H31 0457
Revision: 00000000 Serial number: 618930000003D2
Coding: 01FA8AA1242229700379060141C92980512494C0608294F300200078C002
Shop #: WSC 00028 028 00023
ASAM Dataset: EV_Brake1UDSContiMK100IPB 033001
ROD: EV_Brake1UDSContiMK100IPB_033_VW37.rod
VCID: 7BA0FECB1363F71F0E8-802E
No fault code found.
Address 08: Auto HVAC (J301) Labels:| 5G0-907-426.clb
Part No SW: 5G0 907 426 M HW: 5G0 907 426 M
Component: AC Manuell H01 0705
Revision: 00001K06
Coding: 00120004200100001000000000000000
ASAM Dataset: EV_ACManueBHBVW37X 003019
ROD: EV_ACManueBHBVW37X_003.rod
VCID: 353428F375C7E16FB8C-8060
Fresh Air Blower Front:
Refrigerant Pressure And Temperature Sender:
Address 09: *********************************** Cent. Elect. (J519) Labels:| 5Q0-937-08X-BV1.clb
Part No SW: 5Q0 937 084 R HW: 5Q0 937 084 R
Component: BCM MQBAB B H14 0112
Serial number: 00011318501163
Coding: 03000842C20100530BA44000000403081000000000000000000000000000
ASAM Dataset: EV_BCMCONTI 011001
ROD: EV_BCMBOSCH_011.rod
VCID: 47C8523B1F2B63FFDA0-8012
Control Unit For Wiper Motor:
Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 130630 042 0551
Serial number: 130705013045
Coding: 0E4DDD
1 Fault Found:
204546 - Remote key 2
B147A 18 [009] - Current Too Low
Freeze Frame:
Fault Priority: 4
Fault Frequency: 7
Reset counter: 232
Mileage: 104715 km
Date: 2017.10.30
Time: 10:40:56
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 5Q0 959 655 C HW: 5Q0 959 655 C
Component: AirbagVW20 011 0361
Serial number: 003F5R06DRPZ
Coding: 98CCC000000000005C0000CF00C800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002126
ROD: EV_AirbaVW20SMEVW37X_VW37.rod
VCID: 40DA49273A0554C71BA-8014
Side Sensor Driver Front:
Subsystem 1 - Part No SW: ----------- HW: 480 000 307 13
Component: SideSensor_Df 001 0887
Serial number: 357670000001A4515D0O
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 2 - Part No SW: ----------- HW: 480 001 207 13
Component: SideSensor_Pf 001 0887
Serial number: 35867000000A69353D0Z
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 3 - Part No SW: ----------- HW: 480 401 307 13
Component: SideSensor_Dr 001 6149
Serial number: 3516502B5106FA43D25B
Coding: 2D2D2D
Side Sensor Passenger Rear:
Subsystem 4 - Part No SW: ----------- HW: 480 401 307 13
Component: SideSensor_Pr 001 6149
Serial number: 3526502B5106FA44030$
Coding: 2D2D2D
Front Sensor Driver:
Subsystem 5 - Part No SW: ----------- HW: 480 400 507 14
Component: FrontSensor_D 001 6149
Serial number: 3556502B51656B8260FG
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels:| 5Q0-953-549.clb
Part No SW: 5Q0 953 549 A HW: 5Q0 953 549 A
Component: Lenks. Modul 007 0070
Revision: -------- Serial number: 05121304721345
Coding: 0600
Shop #: WSC 62051 001 1048576
ASAM Dataset: EV_SMLSKLOMQB 009001
ROD: EV_SMLSKLOMQB_009_VW37.rod
VCID: 3A2E3BCF5CD90E1755E-806E
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb
Part No SW: 5G0 920 951 HW: 5G0 920 951
Component: KOMBI 152 2210
Coding: 27A401002300260001080800040000
ASAM Dataset: EV_DashBoardVDDMQBAB 008031
ROD: EV_DashBoardVDDMQBAB_008_VW37.rod
VCID: 6696BFBF78E15AF7C16-8032
Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 K HW: 5Q0 907 530 K
Component: GW MQB Low 210 2147
Revision: -------- Serial number: 08071310800985
Coding: 030000042B086400EF000048080E00010001000000000000000000000000
ASAM Dataset: EV_GatewConti 009011
ROD: EV_GatewConti_009.rod
VCID: 392C24C359DF050F5C4-806C
Alternator:
Battery Monitoring Control Module:
Subsystem 2 - Part No SW: 5Q0 915 181 C HW: 5Q0 915 181 C
Component: J367-BDMHella H03 8042
Serial number: 0555400903
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q4 959 393 HW: 5Q4 959 393
Component: TSG FS 007 0006
Serial number: 0000068210633
Coding: 003002208001020100001000
Shop #: WSC 00028 028 00216
ASAM Dataset: EV_DCUDriveSideEWMAXCONT 006001
ROD: EV_DCUDriveSideEWMAXCONT_VW37.rod
VCID: 55F48873D587C16F58C-8000
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 5Q0 909 144 L HW: 5Q0 909 144 M
Component: EPS_MQB_ZFLS 127 1021
Coding: 01
ASAM Dataset: EV_SteerAssisMQB 008022
ROD: EV_SteerAssisMQB_008.rod
VCID: 3D2430D34DF7392F70C-8068
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q4 959 392 HW: 5Q4 959 392
Component: TSG BFS 007 0006
Serial number: 0000067085502
Coding: 003000208001020100801000
ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001
ROD: EV_DCUPasseSideEWMAXCONT_VW37.rod
VCID: 7F580ADB077BEB3F220-802A
Address 5F:********************************* Information Electr. (J794) Labels:| 5G0-035-MIB-STD1.clb
Part No SW: 5G0 035 820 A HW: 5G0 035 820 A
Component: MU-S-D-ER 040 0421
Serial number: V5C01307130754
Coding: 02730000FF00000021111201002800001F0100060100010001
ASAM Dataset: EV_MUStd4CPASE 002039
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 1F18EA5BE73B4B3F420-804A
Operating And Display Unit 1:
Subsystem 1 - Part No SW: 5G0 919 605 HW: 5G0 919 605
Component: ABT_Std_Radio H44 0020
Serial number: VWZ8Z9N24036RK
1 Fault Found:
6145 - Display and Control Head 1 for Information Electronics
B129E 07 [008] - Mechanical Failure
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 36
Mileage: 106088 km
Date: 2017.12.06
Time: 09:06:35
Voltage terminal 30: 14.8 V
End----------(Elapsed Time: 00:59, VBatt start/end: 14.7V/14.7V)-----------
Scotland (U.K.)
Mk7 Golf GT Estate
Low boost.
Freeze Frame:
Fault Priority: 2
Fault Frequency: 39
Mileage: 105878 km
Date: 2017.11.27
Time: 14:38:27
Coding: 0E4DDD
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 7
Reset counter: 232
Mileage: 104715 km
Date: 2017.10.30
Time: 10:40:56
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 36
Mileage: 106088 km
Date: 2017.12.06
Time: 09:06:35
The bold bits in the engine section are too high eg the mV required to operate the servo actuator means that the pivot joint is seizing......
Just look at my thread & the links in it for the adjustment that's required to be done ...you might have a threaded rod that's you adjust...
Scotland (U.K.)
Mk7 Golf GT Estate
Thanks Dave.
Merry Xmas
No problems, its just as I suspected at the beginning..
I recon that this will be a well known fault in the next few years....mind you it is now...
Just to sort once & for all you have to remove the servo unit & remove/scrape all the crud from the pivot & then grease with proper grease...
"just greasing it" is just a temporary fix as the old crud is still interfering in the movement of the pivot...
If you are DIY the job use the VW hot bolt paste as cheaper than what I got & is what VW are using from the factory (now)
Danishmk7
Mikkel26
Vw mk7 2013 1,4 cxsa
hi I know this is an old thread but I have exactly the same problem now .. I googled the error code and it came out as the first.
I can not find the thread you have written about adjusting the arm on the turbo. :(
should I just adjust until the arm is not loose anymore or? ?
Scotland (U.K.)
Mk7 Golf GT Estate
I wrote a thread on greasing the turbo servo actuator arm pivot point as my arm in not adjustable (CHPA engine code)
That thread is here:-
How to fix the turbo wastegate rattle on the Mk7 Golf 1.4lt TSI (140/150PS) | GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum
That thread contains a link to a Ross-Tech website page with the VCDS procedure on adjusting the arm where you can adjust it..that is here:-
How do I reset or activate wastegate actuator on CHPA 1.4lt TSI MK7 Golf | Ross-Tech Forums
