Had this on VCDS now.
As can be seen there are three faults.
Low boost.
Low battery in remote
And a dirty connection on the instrument head.
Do the figures point to anything for the boost pressure?
Thursday,21,December,2017,19:44:09:27004
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 17.8.0.1 HEX-V2 CB: 0.4401.4
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: WVWZZZAUZEP024216 License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZEP024216 Mileage: 106659km-66274miles
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
Address 01: Engine (J623-CXSA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 016 DE HW: 04E 907 309 A
Component: 1.4l R4 TSI H08 5672
Revision: WAH08---
Coding: 01190012230411082000
Shop #: WSC 00028 028 00058
ASAM Dataset: EV_ECM14TFS01104E906016DE 002002
ROD: EV_ECM14TFS01104E906016DE_VW37.rod
VCID: 688AB18772F54C87F3A-803C
1 Fault Found:******************************
19404 - Turbo/Super Charger Boost System
P2263 00 [168] - Performance
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 39
Mileage: 105878 km
Date: 2017.11.27
Time: 14:38:27
Engine speed: 1742.50 /min
Normed load value: 9.0 %
Vehicle speed: 31 km/h
Coolant temperature: 49 °C
Intake air temperature: 22 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 14.795 V
Unlearning counter according OBD: 40
Charge pressure actuator: specified position: 140.00 %
Bypass valve f high press turboch turbine inlet: actual value: 100.29 %
Charge pressure actuator: adaptation for lower stop: 4490.6 mV
Bypass valve for high press turbocharger turbine inlet: status-Bit 0: 0
Bypass valve for high press turbocharger turbine inlet: status-Bit 16: 0
Bypass valve for high press turbocharger turbine inlet: status-Bit 24: 55
Bypass valve for high press turbocharger turbine inlet: status-Bit 8: 66
Bypass valve for high press turboch turbine inlet: uncond volt: 4503.0 mV
Charge air pressure: actual value: 1039.69 hPa
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 907 379 AA HW: 5Q0 907 379 G
Component: ESC H31 0457
Revision: 00000000 Serial number: 618930000003D2
Coding: 01FA8AA1242229700379060141C92980512494C0608294F300200078C002
Shop #: WSC 00028 028 00023
ASAM Dataset: EV_Brake1UDSContiMK100IPB 033001
ROD: EV_Brake1UDSContiMK100IPB_033_VW37.rod
VCID: 7BA0FECB1363F71F0E8-802E
No fault code found.
Address 08: Auto HVAC (J301) Labels:| 5G0-907-426.clb
Part No SW: 5G0 907 426 M HW: 5G0 907 426 M
Component: AC Manuell H01 0705
Revision: 00001K06
Coding: 00120004200100001000000000000000
ASAM Dataset: EV_ACManueBHBVW37X 003019
ROD: EV_ACManueBHBVW37X_003.rod
VCID: 353428F375C7E16FB8C-8060
Fresh Air Blower Front:
Refrigerant Pressure And Temperature Sender:
Address 09: *********************************** Cent. Elect. (J519) Labels:| 5Q0-937-08X-BV1.clb
Part No SW: 5Q0 937 084 R HW: 5Q0 937 084 R
Component: BCM MQBAB B H14 0112
Serial number: 00011318501163
Coding: 03000842C20100530BA44000000403081000000000000000000000000000
ASAM Dataset: EV_BCMCONTI 011001
ROD: EV_BCMBOSCH_011.rod
VCID: 47C8523B1F2B63FFDA0-8012
Control Unit For Wiper Motor:
Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 130630 042 0551
Serial number: 130705013045
Coding: 0E4DDD
1 Fault Found:
204546 - Remote key 2
B147A 18 [009] - Current Too Low
Freeze Frame:
Fault Priority: 4
Fault Frequency: 7
Reset counter: 232
Mileage: 104715 km
Date: 2017.10.30
Time: 10:40:56
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 5Q0 959 655 C HW: 5Q0 959 655 C
Component: AirbagVW20 011 0361
Serial number: 003F5R06DRPZ
Coding: 98CCC000000000005C0000CF00C800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002126
ROD: EV_AirbaVW20SMEVW37X_VW37.rod
VCID: 40DA49273A0554C71BA-8014
Side Sensor Driver Front:
Subsystem 1 - Part No SW: ----------- HW: 480 000 307 13
Component: SideSensor_Df 001 0887
Serial number: 357670000001A4515D0O
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 2 - Part No SW: ----------- HW: 480 001 207 13
Component: SideSensor_Pf 001 0887
Serial number: 35867000000A69353D0Z
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 3 - Part No SW: ----------- HW: 480 401 307 13
Component: SideSensor_Dr 001 6149
Serial number: 3516502B5106FA43D25B
Coding: 2D2D2D
Side Sensor Passenger Rear:
Subsystem 4 - Part No SW: ----------- HW: 480 401 307 13
Component: SideSensor_Pr 001 6149
Serial number: 3526502B5106FA44030$
Coding: 2D2D2D
Front Sensor Driver:
Subsystem 5 - Part No SW: ----------- HW: 480 400 507 14
Component: FrontSensor_D 001 6149
Serial number: 3556502B51656B8260FG
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels:| 5Q0-953-549.clb
Part No SW: 5Q0 953 549 A HW: 5Q0 953 549 A
Component: Lenks. Modul 007 0070
Revision: -------- Serial number: 05121304721345
Coding: 0600
Shop #: WSC 62051 001 1048576
ASAM Dataset: EV_SMLSKLOMQB 009001
ROD: EV_SMLSKLOMQB_009_VW37.rod
VCID: 3A2E3BCF5CD90E1755E-806E
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb
Part No SW: 5G0 920 951 HW: 5G0 920 951
Component: KOMBI 152 2210
Coding: 27A401002300260001080800040000
ASAM Dataset: EV_DashBoardVDDMQBAB 008031
ROD: EV_DashBoardVDDMQBAB_008_VW37.rod
VCID: 6696BFBF78E15AF7C16-8032
Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 K HW: 5Q0 907 530 K
Component: GW MQB Low 210 2147
Revision: -------- Serial number: 08071310800985
Coding: 030000042B086400EF000048080E00010001000000000000000000000000
ASAM Dataset: EV_GatewConti 009011
ROD: EV_GatewConti_009.rod
VCID: 392C24C359DF050F5C4-806C
Alternator:
Battery Monitoring Control Module:
Subsystem 2 - Part No SW: 5Q0 915 181 C HW: 5Q0 915 181 C
Component: J367-BDMHella H03 8042
Serial number: 0555400903
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q4 959 393 HW: 5Q4 959 393
Component: TSG FS 007 0006
Serial number: 0000068210633
Coding: 003002208001020100001000
Shop #: WSC 00028 028 00216
ASAM Dataset: EV_DCUDriveSideEWMAXCONT 006001
ROD: EV_DCUDriveSideEWMAXCONT_VW37.rod
VCID: 55F48873D587C16F58C-8000
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 5Q0 909 144 L HW: 5Q0 909 144 M
Component: EPS_MQB_ZFLS 127 1021
Coding: 01
ASAM Dataset: EV_SteerAssisMQB 008022
ROD: EV_SteerAssisMQB_008.rod
VCID: 3D2430D34DF7392F70C-8068
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q4 959 392 HW: 5Q4 959 392
Component: TSG BFS 007 0006
Serial number: 0000067085502
Coding: 003000208001020100801000
ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001
ROD: EV_DCUPasseSideEWMAXCONT_VW37.rod
VCID: 7F580ADB077BEB3F220-802A
Address 5F:********************************* Information Electr. (J794) Labels:| 5G0-035-MIB-STD1.clb
Part No SW: 5G0 035 820 A HW: 5G0 035 820 A
Component: MU-S-D-ER 040 0421
Serial number: V5C01307130754
Coding: 02730000FF00000021111201002800001F0100060100010001
ASAM Dataset: EV_MUStd4CPASE 002039
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 1F18EA5BE73B4B3F420-804A
Operating And Display Unit 1:
Subsystem 1 - Part No SW: 5G0 919 605 HW: 5G0 919 605
Component: ABT_Std_Radio H44 0020
Serial number: VWZ8Z9N24036RK
1 Fault Found:
6145 - Display and Control Head 1 for Information Electronics
B129E 07 [008] - Mechanical Failure
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 36
Mileage: 106088 km
Date: 2017.12.06
Time: 09:06:35
Voltage terminal 30: 14.8 V
End----------(Elapsed Time: 00:59, VBatt start/end: 14.7V/14.7V)-----------
