Audi TT-RS front brake uprade on a 7R
Dragk913
DFW, Tx
I don't unfortunately. The kit sells from ECS and a few other places for $2500 or so I believe.
Thanks for the links! I’m definitely going to keep an eye out for a deal like the one you got:)
Chuckable
Resurrecting this thread. I've read all about the TT RS brake upgrade on different forums, and from what I can tell the hub/spindle bracket is the only part that doesn't "plug and play" aside from a bit of filing needed for the body brake line bracket. Is that correct?
Someone mentioned getting custom hoses made that adapt the stock GTI lines to the TT RS calipers as a solution, but I haven't seen any more discussion on that. Has anyone gone this route?
mattkosem1
OH, US
I mean, it's a direct bolt on kit designed to allow the TTRS calipers to be fitted to an MKVII car with readily available inexpensive rotors. You can email them to ask, but it seems to include all that is needed for a direct fit.
A3SBQ
Norway
Chuckable
I have this Kit. Plug and play.
All hw is included.
Remember that you will need spacers when 340/345 mm disc is used in combination with 4pot TTRS calipers. Wheel design is what dictates the thickness of the spacers...
Sent fra min SM-G955F via Tapatalk
Can you tell if it’d be plug and play with the 370mm discs too as far as the brake line mounting on the spindle?
A3SBQ
Norway
You are talking about two different things.
I you go the 370 mm disc oem size you do not need to buy anything but new brake lines..
Stock 370 mm disc from TTRS (not RS3 8P) Will fit strait on. This includes oem caliper brackets.. [emoji4]
Chuckable
Thanks but maybe I’m not communicating this well. The minor issue with the 370mm rotors with RS brakes is apparently the brake line bracket. Here’s the thread on it:
https://www.golfmk7.com/forums/showthread.php?t=8864
http://s1370.photobucket.com/user/Matthew_Eagan/media/image.jpg1_zpsogje0cxq.jpg.html
From what I’ve read, I’m wondering if the fix is custom brake lines that use all Mk7 Golf R brake lines except at the caliper connection, which is what I’m wondering if the Vagremtexhnic kit does.
dc22
Virginia
Ever get any clarity on this last question? I am also wondering the ssme.
Sent from my SM-N950U1 using Tapatalk
carchrism5
CT
GTI
You just need TT-RS brake lines and you can easily modify the bracket for the line, it is a very minor thing.
