I don't unfortunately. The kit sells from ECS and a few other places for $2500 or so I believe.
Thanks for the links! I’m definitely going to keep an eye out for a deal like the one you got
I have this Kit. Plug and play.
All hw is included.
Remember that you will need spacers when 340/345 mm disc is used in combination with 4pot TTRS calipers. Wheel design is what dictates the thickness of the spacers...
Sent fra min SM-G955F via Tapatalk
You are talking about two different things.Can you tell if it’d be plug and play with the 370mm discs too as far as the brake line mounting on the spindle?
I you go the 370 mm disc oem size you do not need to buy anything but new brake lines..
Stock 370 mm disc from TTRS (not RS3 8P) Will fit strait on. This includes oem caliper brackets.. [emoji4]
Ever get any clarity on this last question? I am also wondering the ssme.
Sent from my SM-N950U1 using Tapatalk
