kimchee411
- NorCal
I just installed my Koni yellows with H&R OE sport springs and I am getting noise in the rear too!
Initially I torqued the shocks without load, but after seeing it should be at curb weight I went back in and made sure the shock mounts and lower bolts were torqued to spec with the hub center to fender gap at the normally loaded distance by jacking up the lower transverse link. I did not remove and re-torque though as I would technically need to replace the bolts and nuts. Giving the shocks some good hard taps with a closed fist doesn't produce any vibration or rattling.
This is the noise when pushing down on the trunk. Dark/lower pitched sound is with the phone in the trunk and higher pitched is outside. It does sound like it's coming from the upper shock/mount area.
Otherwise the car drives great so far. I would say it's about 20-30% stiffer than stock with rears at 1/4 turn from full soft and fronts at 1/2 turn from full soft.
