Is that what happens when you pee doing a break dance?brake fluid.
(Break fluid is something entirely different...)
If that is brake fluid, then I'd give the car to the dealer and say "call me when you've found the leak and fixed it. I'll return your loaner then"
If they say anything, then ask them "do you really expect me to drive around in a car with leaking brake fluid? Please put that in writing so my heirs can own this dealership when the brakes fail."
The only thing that can leak on top of the trans that is related to brake fluid is the bleeder block and line for the slave cylinder. You can inspect both if you pull the airbox off and have a look.
Thank you guys. I'll double check dsg filter housing, and bleeder block (just need to find out how it looks )
Seriously? No way! His DSG as noted by the DSG filter in the picture, is actually a manual with a slave cylinder? Color me purple batman.
There is no bleeder block, that is for manuals only. The russiankid couldn't tell you had a DSG...
But anyway, with that much fluid you would notice your brake fluid reservoir low, depending on brake pad wear could even be under the min line. If it is truly brake fluid and not DSG.
Yeah, I am keeping an eye on brake fluid level. It is probably at 90% or so. I was told DSG fluid stinks badly, and this stuff does not and does not look like motor oil, coolant or washer fluid (that would just evaporate). I smelled brake fluid reservoir cap and it seems the same.
Just trying to understand what exactly can leak fluid under normal conditions. reservoir cap? Is this stuff under such pressure that it can leak through the cap rubber seal? Would I see some residue than or brake fluid is super thin?
