Suspension Experts: Did I put the spring on correctly
Letcher77
AZ
Calling all suspension experts. I installed a set of Eibach spring last weekend and since I have been getting a creaking noise on the front passenger side. Took the wheel off and re torqued everything and that didn't fix it. Next thought is that the spring isn't seated all the way. The picture below is how it looks after I took the strut out today. Does it look correct? When the top of the strut gets bolted into the car with the 3 bolts is there a certain way it needs to be facing? How does everything else look?
NopeR
18 Golf R
The notch for the upper strut bearing/mount has to be pointing towards the engine when installing. Make sure the top strut bolt is tight as fuck (impact usually is the best method).
Otherwise it looks fine from the pictures you've posted.
Sent from my SM-G965W using Tapatalk
blaqsheep
Canada
IS38 GTI
You can zip it on with an impact gun but for torquing to spec, a 21mm open socket and allen socket is the correct way.
As per Gti jake's post here: https://www.golfmk7.com/forums/showthread.php?t=25214
Otherwise OP, everything looks to be in order.
Letcher77
AZ
Well not sure exact what I was doing wrong. Put it back together a made sure I followed your guys' instructions and the sound seems to be gone now!
Thanks!
Carlosfandang0
UK
2016 3Dr GTi DSG CSG
Although it probably wasn’t the culprit here it may be worth pointing out that the dust cover on the shock can be the cause of creaking and knocking sounds if not inserted correctly into the top mount, VW have a TPI for it #2035859/5.
Carlosfandang0
UK
Eibach springs, but no upgraded dampers? Yikes. Not a good combination with the stock dampers.
Eibach claim their springs are designed to be used with stock dampers, I’ve done so with two different golfs now with great results.
Navi
BK/NYC/Hamptons
Install looks good to me. I know you said the noise is gone but the following is important also: Did you trim the bump stop? Doesn’t look like it. Also, make sure to torque the strut to strut mount nut with the spring compressed.
Carlosfandang0
UK
Eibachs usually come with the shorter bump stop, so it may be that it doesn’t look trimmed due it being a new one!
Carlosfandang0
UK
In this picture the dust cover appears to be upside down,
As mentioned above these can cause squeaks or rattles if not fitted correctly, hence the TPI, they are supposed to push up firmly into the top mount bearing but move freely at the bottom,
Picture below is from the TPI,
The bit in the red circle in this case is pushed too far up and should sit level with the green arrow, this normally causes squeaks, rattles are usually caused by the dust cover not being fixed properly at the top and tapping on the strut!
VL3X
Delaware
2017 GTI SE
These look like the black "Prokit" springs, which only lower about ~1" and tend to work nicely with stock struts for a long time. The red "Sportlines" are the ones that drop 2"+ and will blow out the struts rather quickly.
Tooly
Kelowna, BC Canada
2018 GTI Autobahn
Dumb question, what happens if you don't torque it down while the spring is compressed?
-Dutch-
RI
The spring will be exerting force into the nut, preventing it from being torqued to the correct value.
Navi
BK/NYC/Hamptons
This.
It will end up coming loose bc it will be torqued significantly less than you think it is. This will cause a squeaking.
