Clutch on the 7R
dub_guy
GTA
How is the clutch on the 7r? Can it hold stock power or is it going to start slipping?
I'm in a 6MT GTI right now, so I know how the GTI clutch can't hold a tune. Considering going to an R, and wondering if the clutch will hold the stock power, say out 120,000km. Sachs has said that is the lifespan of one of their DMFW, so living to that point would put me out past warranty, so clutch + tune could come at the same time.
I did cases in google of the clutch no holding stock power, so I'm curious what people say here.
MiamiBourne
South Florida
2016 6MT Golf R Oryx
Mine was fine up to 14k before I decided to put in the DKM since I was going to get tuned (preventive). I know I have read of some people with stock tune having their clutch slip early. I believe it's maybe the rear main seal leaking that causes slipping but that doesn't appear to be everyone.
Then again there is a guy that is full stage 2 on the stock clutch with no issues. I'm thinking it's maybe because he's in a place with high altitude so that's keeping the clutch alive longer.
Off topic:
Any news on your progress with DKM? I just quoted you on the DKM thread for an update.
dub_guy
GTA
I'm thinking if I get the R, to run stock until I run the clutch out and prefer that be at least 100,000km.
I responded over in the DKM thread.
d1ngleberry
PDX
I had no slipping at stock power. Installed my JB4 at 10k miles and by 15k it was slipping a bit in 4th, 5th, and 6th. It gradually got worse until I uninstalled the JB4 at about 18k, at which point the clutch held stock power without slipping at all.
Based on that, I'd guess my stock clutch would have lasted a quite a while at stock power levels. Alas, I upgraded to the DKM stage 3.
The Fed
Old Guys Rule
Florida
There are people who have their clutch last the life of the car. I'm betting they granny shift and never floor it, especially in the higher gears. From all the reports in here, even given that they're enthusiasts, the clutch is just too weak. It's all in the name of saving weight.
I would wait until it slips. You might get lucky. There's no harm in replacing it when it fails. It's not warranted, at least not after one 1/12. It's not like you'll be denied for warranty work as long as you only use a piggyback.
spessx
Texas
Mine started slipping intermittently at 13,700 miles with stock power. Mostly on the highway on rolling hills in cool weather. I haven't replaced it because I don't want to fork over the $2,500 for an RSR and it doesn't slip that often.
cbass
Couple Loose Screws
Peenhandle
milfs
I don't put much credence in the stories of people with stock cars having the clutch go early. Sure there is defects, and some mechanical failures that happen, but I would be willing to bet that some of the people who have had premature clutch failure are not the most sympathetic to their wear items. You either learn to make your purchases last, or you learn to be comfortable with the cost.
The Fed
Old Guys Rule
Florida
If you want a clutch to last, don't buy a car with 300 lb. ft. of torque. It ain't like the old days, when clutches were big and heavy, and could take much more than stock power.
PowerDemon
Richmond, VA
Golf GTI, Camaro ZL1
Can a stock clutch handle a DP?
A downpipe will not run properly on a stock tune so you would have to tune the car to work with the DP. And at that point you have to start worrying about clutch slippage.
If you just installed a downpipe on a stock car I can't imagine you’d have any problems, as you will not be making much more power if any without a supporting tune.
