My car is also in the shop for a new DSG....(been 3 weeks)
Same exact scenario - 40k trans service, 5th and 6th gear grinding.
Just putting this out there because it seems like a common occurrence.
Grinding before, or after the service?
Grinding after the service.
The good part about your posts is the fact you spend little time making things up.
Meanwhile, us manual guys:
Is that you waiting for your new clutch to arrive?
Is it? You're only the second person I've heard of having this issue. Not that it doesn't concern me, because I've got my 40k service coming up and I'm sorely tempted to just do the DSG fluid change myself (especially since I'm tuned).
Just wanting to know if you can cite any others with this problem, if anything to see if the trend is improper service or if it might be something else.
It makes me wonder if there isn't some truth to the old if it ain't broke don't fix it. I mean obviously if it's in the service manual it needs to be done to maintain warranty status but I had always heard of people going in for transmission flushes with functioning transmissions and when they got them back they had transmissions that started slipping. Maybe the act of flushing it dislodged something since i'm assuming the DSG fluid going in should be the same as what came out.
I cant imagine the replacement fluid had particulates in it that it wasn't supposed to; but maybe we both got DSG fluid from the same batch? Tomorrow will be 4 full weeks so far, hopefully ill get my car back soon.
You want to see transmission failures? Go look into the forum buzz on 1999 on up Honda V6 cars, especially the Odyssey van. See when it started and how much of it started within what small time frame. Now there's some indication of widespread transmission failures, pretty quickly.
