nkresho
suck, squish, bang, blow
- Pittsburgh
- 2022 Q3
Will a DSP fix my volume control? Volume too high at start & too low past halfway
I installed a pair of amps a few months ago and still can't get my volume situation sorted out. It's working, just has bad granularity.
4 channels of speaker level signal run from behind glovebox to trunk. This runs to the 4channel amp inputs. The front channel high-level input splits to the sub amp speaker-level input as well. On the output side of the 4 channel amp, another bundle of 4 channels runs back to the glovebox and then to the factory speakers.
4 gauge power to battery, distributed to 8 gauge to each amp
Alpine MRV-F300 (4 channels, 4x50RMS) to factory interior speakers
Alpine MRV-M500 (mono 500x1) to JL 10w3v2d4 (x1) in center of spare tire
The two issue I am having:
volume seems to adjust appropriately from that one notch to about 1/2 way...
Gain control on both amps were set a number of ways to try to remedy this:
The 4 channel amp gains never make it past about 1/4 or 1/2. I can get distortion over these levels. The issue is that the distortion comes on at about 1/2 headunit volume just as it does at 100%.
So, I am thinking there's an issue with the factory eq curve. Protecting speakers or limiting distortion.
I'm plenty happy with the sub output. Bass is clean and appropriate to fullrange speakers. Still no real increase past halfway on the volume knob, but sounds in proper proportion to the rest of the system.
Here's what I think might be happening:
The factory system is sensing impedance (or something else?) at the amplifier's high level input circuit, and it's being confused, as it typically sees an actual speaker load. This could be affecting the low (level 1) volume as well as the past halfway volume.
Past halfway on the volume knob, the car is automatically limiting output to protect speakers. I'm not sure how this might be achieved. I'm equally unsure of how to bypass it.
I've read about mk6 or mk5 cars being able to VAGCOM out the factory EQ. I'm not seeing anything for our cars. This would be a great place to start, since it's free and I could do it easily.
If anyone is aware of any coding in VCDS, please share. I would love to try this first.
Here's a thread that gets somewhat close, but not exactly what I need. http://forums.ross-tech.com/showthr...-and-Fender-move-to-Dynaudio-Long-coding-help (first two posts)
Additionally, I've been reading up on the audiocontrol LC7i, JL audio FIX-86, and audison bit ten.
What do you all suspect I will see, with regards to problem 1 and problem 2, if I install one of these? They range from the $115 range (lc7i) to $340 (bit ten & JL).
Preemptive thanks
- 2016 S model (no fender audio)
- factory interior speakers
- factory head unit
- Using high (speaker level) inputs on both amps
- When I turn any audio source on, with the volume all the way down, I then turn it up one notch. That one notch is louder than it should be. There's no real quiet setting any more. It's like it comes on at volume 5, rather than volume 1. My wife is not happy with this function and regularly mentions it. It's noticeable.
- When I turn the volume up, past 1/2 way, there's no audible increase in sound. It doesn't get louder, doesn't add more bass from the sub, no more distortion, no audible clipping, nothing... It just stays the same all the way to the 100% level.
- radio volume at about 80%, turn up gain until there's slight distortion of sound, then back down ~1/8th turn.
Still no change at volume 1, still no audible increase past halfway
- radio volume at 100%, turn up gain until there's slight distortion of sound, then back down 1/8th turn.
- radio volume at one notch, leave gain all the way down.
Still relatively loud at volume 1 on head unit. Pretty quiet to 1/2 way and to 100%
Preemptive thanks
