Jasonxerday
- Torrance
- 2017 golf S
Just got APR! Now it’s time for wheels and tires! Recommendation! I have a 2017 golf s
Sweet thanks man!Depends on budget and intent. On a budget, I always recommend Audi A3 or A4 wheels. They're good quality, they fit perfectly with no hub rings (A3), 18's are 8" wide instead of gti 7.5"and you can usually find them pretty cheap.
Anything else, there's a thousand options.
You can read up on here. There's tons of wheel threads
Not all of A4 wheels are 57.1mm hub bore. B8 and later are 66.67mm hub bore.Depends on budget and intent. On a budget, I always recommend Audi A3 or A4 wheels. They're good quality, they fit perfectly with no hub rings (A3), 18's are 8" wide instead of gti 7.5"and you can usually find them pretty cheap.
I wanna get aftermarket!It depends on lot of other variables and i dont see any such info in the post.
- Are you planning oem or aftermarket.
- Whats your budget.
- Are you sticking with stock size or do you want to go bigger.
There are n number of threads about wheels in the forum. If you do some research and zero in some options, people can share their experiences with those specific wheels.
What do i eat for lunch. Oh wait, i might need a new thread for this.
Less than $1000... does that include tires?I wanna get aftermarket!
Budget less than 1000
I want them bigger! All season tires as well
Is that with tires or no? I am sssuming not!MY 2019 Golf SE that came with 17" VW Alloy's
replaced with these VMR710 18x8.5 et 45 & ($960)
& Continental DWS06 235/40 purchased at DiscountTireDirect.com
The Fronts are very close to FLUSH Fitment
The Rears are IN approx 10mm and Im working on Finding
Spacers that Fit this Mk7.5 Golf REAR
View attachment 175969View attachment 175970View attachment 175971
Mounting.Balancing,Shipping included.....
There are numerous options for quality spacers available. DAP, ECS, H&R, etc. Why is this in classified?Jason, I'm measuring IN from Carpenters Level held vertical flush with White Edge of Rear Qtr Pnl/Fender to
Sidewall of Tire and get approx 10mm.....
