What's wrong with my Dynamic adaptive lights?
le0n1
Norway
Got a error message in my car today.
Pops up when I start driving, not when I start the car.
See picture. Translated into english it says:
"Error: Dynamic adaptive lights"
Seems like the adaptive mainlights works fine. It's the foglights who normaly lights up when I indicate and turn into a corner in low speed that dose'nt work.
Whan can it be thats wrong??
pjr
Scotland
Have you checked that the fog lights work as fog lights (rather than cornering lights) - it might just be that one of the bulbs has blown.
I got a similar message when one of my cornering lights failed, although my cornering lights are in the main headlight unit rather than using the fog lights.
le0n1
Norway
Fog lights and all other lights seems to work fine.
Sent fra min E5823 via Tapatalk
pjr
Scotland
If you have xenons, then your cornering lights will be in the main headlight unit - might be worth checking those bulbs as well.
le0n1
Norway
I was sure it was in my foglights, but will definitely check the main headlight unit. I do have xenon. Will it be possible to turn the wheel when the car is not driving to check the cornering lights?
pjr
Scotland
Just turn the indicator on - then you don't need to turn the wheel.
You might need to remove the bulb to check it, as the error will stop both of them from working (if it's a bulb failure)
