They will fit as long as the new lug bolts are 17mm, and they most likely will be. The stock lug bolts have an indent on the top so the cover can be pulled off with the hook tool. If the longer bolts don't have the indent they will be harder to remove, or you can get bolt covers that have a "lip" on the outer edge and use a different tool for removal.
Make sure you get the correct bolts: OEM wheels use ball seat, most after market use cone seat.
