Universal Rally Armor Cut/Fit Help
SRGTD
UK
I'm sorry, I've never put on mud flaps I'm a giant doofus apparently x D. I'm still super confused by this. What does the optional mean? I cut away everything up to it?
I’m assuming it means it’s possible to fit the fronts with just the two fixings through the holes on the left hand side of the diagram. The ‘optional’ additional fittings would presumably provide extra support and make them more secure though.
I might be completely wrong though.🤔
Terriquez88
That is exactly right. The optional hole locations mean that it’s up to you if you wnat to drill Into your fender liner. But the other holes are more than enough to hold up the guard and uses the stock screw location. I decided to make the optional holes to secure it a bit more since there could be a possibility of your tire hitting it when you turn.
